Question about Acer TravelMate 2300 Notebook
Touchpad is non-responsive
My laptop touchpad does not respond. I have rebooted and hard reset to no avail. Any suggestions?
  • pgmontgo Sep 20, 2008
    I can't even do that because I can't get the touchpad to work.
    Sergeant:
    Champion:
  • 258 Answers
Check the driver if its installed correctly in device manager
start>setings>control panel>system>hardware>device manager>look for the listings if you found the touchpad hardware is installed correctly then tell me the model of the laptop
Posted on Sep 20, 2008
  • Efren Javier
    Efren Javier Sep 21, 2008
    obtain a usb mouse so that you can check out the device manager
Touch pad malfunctioning
Inorder to fix the Touchpad issue, try the hard reset steps:
Sometimes it is necessary to do a hard reset to erase all of the information in the temporary memory and regain functionality of your PC when it stops responding. For example, doing a hard reset is helpful if your keyboard quits responding, you cannot get your PC to come out of hibernation or sleep mode, or if a software program causes the PC to freeze.
The hard reset will not delete saved files on the hard drive.
Hard Reset Procedure:
1. Disconnect the AC Adapter.
2. Remove the Battery pack.
3. Hold the Power button down for 2 minutes.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
Also make sure that touchpad button is On. It will be just above the touchpad area where you can see the white led which shows that touchpad is on. If the led is in orange, touchpad is off.
If these steps does not work, update the BIOS version from HP website .
In rare case if the issue still persists, you need to restore the notebook to factory settings using Recovery Manager or recovery discs.
Before performing recovery, you need to backup all your data to external hard drive because it will erase the data from the hard drive:
Vista F11 procedure:
1. Reboot the notebook PC.
2. Press F11 when the HP logo displays.
3. When the Recovery Manager appears, click Next .
4. When prompted to use the Microsoft System Restore program, select No and click Next .
5. When prompted to use the System Recovery, select Yes and click Next .
6. Select the option to perform the recovery without backing up files and click Next .
The recovery process will return your PC to the factory image.
or
On some notebooks, the TouchPad can be turned off by pressing an on/off button located near the TouchPad. If the notebook does not have such an on/off button, you can still disable the TouchPad in its settings control panel.
NOTE: You will need to use an external mouse or some other pointing device to control the cursor when the TouchPad is disabled.
To disable the TouchPad:
Click Start , enter mouse in the search field, and then select the Mouse control panel program from the search results.
On the Device Settings tab of the Mouse Properties panel, click the Disable button to turn off the TouchPad.
The TouchPad can be re-enabled when needed.
May 07, 2012 | HP Compaq 6735s Notebook
My touchpad working too bad
If a Dell cursor is jumpy when you type then the touchcheck/palmcheck needs to be enabled in the touchpad driver advanced settings. if advanced functions like scroll do not work then try installing the touchpad driver (Basic functions are controlled by windows)
If the touchpad has a bad button, or it just non-responsive in a portion of the pad, then the palmrest assembly will need to be replaced.
Jan 30, 2011 | Computers & Internet
How to unlock the pad from an up pavilion dm4-1165dx notebook?
Turning the TouchPad on and off
The TouchPad is turned on at the factory. When the TouchPad zone is active, the light is off.
To turn the TouchPad on and off, quickly double-tap the TouchPad off indicator.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 14, 2010 | HP Pavilion dv6000z Notebook
Our touchpad is not responding to tapping. It
Go into the BIOS (F2). Press Alt-P until you reach "Page 4 of 7". Under "Pointing Device" change the setting from "PS/2-Touchpad" to "PS/2". Reboot.
The touchpad and point stick will still function as long as there isn't a mouse plugged into the PS/2 port. If the mouse is plugged in, it will override the integrated devices.
Sep 23, 2009 | Dell Latitude C640 Notebook
Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Aug 17, 2009 | Compaq Presario CQ60-220US PC Laptop
Touchpad on acer aspire 5100 series is locked
plug in a usb mouse, go to control panel>system>harware>device manager and click on the + sign next to pointing devices. Right click the touchpad and click on uninstall. Reboot the laptop and unplug the usb mouse. This should pick up the touchpad as new hardware and reinstall it. Hopefully this will resolve the problem.
Dec 29, 2008 | Acer Aspire 5100 Notebook
Touchpad no response at all
CHECK CONTROL CIRCUIT AND RELACE TOUCH PAD..
Nov 06, 2008 | GE JVM1650 1000 Watts Microwave Oven
TouchPad non-responsive
go to device manager and reinstall the touchpad synaptics driver...restart your system...it sholud work..otherwise you need to contact lenovo support for touchpad replacement
Feb 08, 2008 | Lenovo 3000 C200 Notebook
Touchpad doesn't respond
MY SOLUTION - Hello, I have Compaq Presario V2000 Laptop and at once my touchpad stopped working.
So i rebooted it several times but it still didn't work.
Then i detached the battery from the laptop and let it like that for 5 min. I attached the battery again and the touchpad was working again.
So, try the simplest solutions first before you start messing with complicating solutions.
Good luck !
Nov 11, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
