Question about Cameras
CD installation error
HELP! I'm unable to reinstall my cd after fixing my system crash. I keep getting a set up failure error 00001618. what would cause this to occur if i've wiped out prior installation files? I am having this problem when installing Olympus Master 2 thar came withmy new camera. Each time I try to install the Olympus Master 2 software, I get an error message: Installation Operation failed: 00001618.
Why??????
  • Cameras Master
  • 5,075 Answers
Assuming this is a Windows installation on the same OS that you used before, are you installing as administrator ?
Posted on Jul 06, 2017
5 Suggested Answers
SOURCE: Camera CD installation error
Disable your Anti-Virus program before starting the installation.
Posted on Apr 12, 2008
SOURCE: Master Software 2 help!
Ditto. Installing on XP w/SP1. Plenty of hard drive space. Pentium 4 w/2GB RAM. Tried different drives. Tried copying CD-ROM to hard drive to verify it was reading of the CD ok. No problem copying but still failing on installation. I also tried by-passing the initial Olympus menu and launching the .msi directly, but that fails in the same way. I haven't found anything on the Olympus website about this, but note their website generates tons of Javascript errors which is not encouraging with respect to Olympus's attention to quality. (This is my first and probably last Olympus.)
Tried pulling the XD media and reading it on the computer but my computer wanted to format the thing (never seen that with SD or Compact Flash, what gives?) so that was a no for the moment.
Finally, I went to the files that I had copied from the CD to my hard drive and double-clicked the OM2_Pack_Framework_2_0_4.cab file found in the OLYMPUS\OLYMPUS Master 2 directory. That contains a bunch of .cab files, that I extracted to another directory. In there, I found a application.cab, which I then extracted to yet another directory. In there, I found OLYMPUS Master.exe. That ran fine when I double clicked on it, but I still had the problem of not being able to read the XD directly, so I hooked the USB up to the camera with the XD back in the camera and was able to transfer the images in that manner.
Posted on Jun 28, 2008
Comment by Jerra: I got it to load for me when it asks you to connect to camera automatically, delete the tick. it took awhile to download from the disc.
Posted on Aug 04, 2008
SOURCE: Olympus Master 2 installion operation failed
I had this problem today when installing Olympus Studio 2. I turned my Spyware and Virus Protection off, and the program installed correctly.
Posted on Dec 09, 2008
My pc will not startup when i turn on it appears it crashed i have boot cd that i created. i tried to repair and it will not. im not sure if im doing it right.. i have windows xp.. the original error it...
Hello, Trace.
Here's some help regarding fixing this error. From HP Support:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=&product=89876&docname=c00188632
If you are still experiencing a problem, your created boot CD is probably faulty.
If it still is not working, depending on your hardware manufacturer, you may be able to access/run Factory Restore. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Please note that Factory Restore restores to the original settings and will wipe out anything that you have installed or saved on your PC.
Hope this helps.
Jan 23, 2010 | Computers & Internet
Ibm thinkpad A31 Windows unable to start normally. Message on blue screen indicating "unmountable_boot_volume". Also got "Kernal_data_inpage_error" message. Does this indicate hard drive failure??
No, this is a known error within Windows. Read more information on it here: http://support.microsoft.com/kb/555302
But, if you are like me and don't like to read, just put your windows XP installation CD into the CD-ROM, boot up from the CD-ROM, DO NOT reinstall the operating system...just repair the installation and run "chkdsk /r".
Once that is done, restart the machine and it should boot up fine.
Jan 08, 2010 | IBM ThinkPad A31 Notebook
I had a system crash and have just recovered xp
CHECK YOUR SOUND CARD DRIVER FROM THE DEVICE MANAGER
IN THE COMPUTER PROPERTIES, IF DRIVER IS INSTALLED
CORRECTLY.
if the driver is not installed buy a universal xp driver cd and install your drivers.
IF THE SOUND DEVICE IS NOT AVAILABLE THEN UNPLUG YOUR SOUND CARD AND REPLUG IT
WELL.
Dec 28, 2009 | Altec Lansing AVS 500 Computer Speakers
My nc10 reported the 'operating system not found' a week or so ago. I've tried everything including trying to reload windows xp from a USB [as the netbook doesn't have a cd drive] At this point I just want...
Sound like your hard drive has crashed so bad that the notebook does not even know it is there. I would replace the hard drive and try to reinstall from external cd-rom . Make sure the external cd-rom is recognized in the bios settings Good Luck
Nov 23, 2009 | Samsung NC10-14GW Notebook
When i on my laptop the log on window start over
hi
i think there is a problem with the operating system
if it is windows and you have the operating system CD then set the bios settings to detect the CD drive as first boot device
insert the windows CD and let it go to the setup area
the first time it asks for the repair or setup select setup
next after it checks for existing windows setup OS and prompts for new setup or repair select Repair - R
this will reinstall all the windows OS again keeping all the existing settings as they are
hope this helped
cheers
pls rate the solution
Jun 28, 2009 | Acer Computers & Internet
My computer crashed win7 theme error
try to boot from windows7 cd-rom, without installing it, choose fixing errors.
if impossible at first try,
press F2-button while system boot(before windows takes over),
enter bios-setup and change
BOOT DEVICE PRIORITY to
1st: CD/DVD
2nd: Hard disk/HDD
3rd: (whatsoever availabe)
please remember to exit BIOS saving changes!
(press Esc button after changing the above, confirm: ...Exit bios saving changes ? - Yes)
if you are asked now :
boot from cd-rom or hdd ?
choose cd-rom, let it work and wait.
in the following, do not reinstall windows 7
but choose a repair option,
leave the setup, remove cd/dvd etc from all drives and reboot, wait.
the regular windows screen should show up...
if this does not work, please ask s.o. who knows around with win 7 or think of downgrading from win7 to winxp professional.
as it is older but reliable, still supported and some win-pro's use it.
win 7 features are available but you'll need time to set up the whole system, incl. drivers etc.
this could work...if not ask me to post some links
now retry to boot from Windows 7 CD-ROM,
do not install, cjoose repa
all i can recommend: if you are a bit into computers, think of swapping from windows 7
Jun 13, 2009 | HP Compaq Presario CQ60Z Notebook
Recovery pro lost power during my recovery of origonal settings
You can still install windows xp without the recovery disc. Just buy a windows xp installer then download the v2 premier driver in the net.
May 04, 2009 | Viscom V2 Premier 17'' LCD Computer...
LG GSA-H55LK problems,just put in computer and keeps getting the blue error screen that it just saved my computer by needing to shut it down its set as a master ,bios reconizes it no driver updates???
Problem : crashed windows
solution format and reinstall everything,
to do this you will need an original windws cd or a recovery cd. Just set the bios to boot from it and follow the onscreen instructions.
the problem steams when windows trys to load the drivers and it fails, it detects it as a hard ware issue and crashes.
Jul 22, 2008 | Computers & Internet
Feb 21, 2008 | Olympus FE-210 Digital Camera
Cameras Logo
65 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
