Lg privilege 1,96ft3, washer&dryer combo model:WD3243RHD. Start working but dosen't take wather. I belive drain pump is gonne. Where to buy part. I'm from Canada.
  • 1,543 Answers
Find nearest service center @ http://ca.lgservice.com/index_b2c.jsp BUT FIRST,.... if your LG WD-3243RHD (note dash is part of this model number) is not pumping out check the filter. Filter is located behind the small access door at the lower left on front of the machine. (There will be some water in the pump area)
Posted on Sep 20, 2008
Do I have to take apart the whole machine to fix the drain pump on my LG WM3455HW washer/dryer combo? I can't seem to find any instructions on this model.
Lucky You. The newer models of LG Combo units WM34xx have the filter on the right hand side and the pump can be changed through the bottom panel.
Nov 17, 2015 | LG Washing Machines
Gives message...oe
On pg 18 of the service manual for this combo, front-load LG washer/dryer, it basically says if the drain's not working and you see an OE error code, clean the drain pump filter and retry. So first do that.
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
Manual above.Below is a great DIY self help washer site, use with manual to sort your problem out.
http://www.washerhelp.co.uk/diy-repair-help.html
Jun 18, 2010 | LG WM-2277HW Front Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
Aug 31, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG Washer/Dryer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LE error, won't spin, I've replaced the sensor
check out the DRAIN MOTOR PUMP ,it could be clogged with lint & debris , just follow the drain hose where it ends connected to a small motor , take it out and clean it , hope this helps AJ
May 17, 2009 | LG WD-3632HW Front Load All-in-One Washer...
LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
