Question about Asko D1706 Built-in Dishwasher
Asko door latch stuck
My asko dishwasher latch has jambed so that the door will not open. The lever you push up to open the door will not move.
  • Anonymous Dec 06, 2008
    My DW door wont open. It is stuck closed.
    How do I get it open?
  • Anonymous Mar 15, 2014
    dishwasher steam venting out top of door damaging cabinetry. Any ideas why this is happening to ASKO D5544 FI
  • 1,031 Answers
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Posted on Sep 20, 2008
  • Starnley Johnwells
    Starnley Johnwells Sep 20, 2008
    pls do appreciate by rating the solution .thanks and goodluck
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
http://www.repairclinic.com/Shop-For-Parts/a9b126d867701/Model-D3251White-Asko-Dishwasher-Parts
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Door won't open
hello,
please follow this instruction
But generally you will see a plastic lever that is touching both the door open button and the area of the door switches.
That lever is what breaks most often, and if you will push up on the door hooks (latch heads) , the door will open.
Pushing on the door open button repeatedly while looking inside will help you figure it out, too.
thank you.
Aug 19, 2010 | Asko W6021 Front Load Washer
Asko 1385: 13 year old dishwasher stops during cycle. If you push on the middle of the door it starts again. It is like the latch is not working properly but by all appearances the latch works fine....
when you latch the door it closes the circuit.
you may have to open the casing of the door to access the switch. it may be stuck or defective.
May 15, 2010 | Asko 1385 Dishwasher
Asko 1385 dishwasher spray arm doesn't stop when door is opened
If there's a fault it's with your door latch/switch cheers
Jan 08, 2009 | Asko 1385 Dishwasher
Asko D3250 not working
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 25, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher d3250 door not closing
the door latch is faulty or needs to be rolled open
Jul 08, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko D1976 detergent dispenser solenoid energized all the time
Replace the waxmotor and the problem should be gone
Jan 19, 2008 | Dishwashers
Detergent lid won't latch shut
The whole dispenser will need to be replaced, they only come complete
Sep 07, 2007 | Asko D1796FI Built-in Dishwasher
Dishwasher does not "pause" (hault) when I open the door
it's the door switch gone bad or the wire going to it has fallen off.
Mar 01, 2007 | Asko D1776 Built-in Dishwasher
Asko D1706 Built-in Dishwasher Logo
1,556 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
