Question about RCA D56W20 56" Rear Projection Television
Cable plug broke off
My wife broke my cable plug off,is their another way to hookup a antenna? using rca cables
  • Anonymous Sep 28, 2008
    but the vcr isnt helping it work
  • 61 Answers
Well first repair the coaxial cable going to your antenna. There is no way you can use RCA cables as a substitution for coaxial cable. They have totally two different properties. You can use the coaxial and feed it to a VCR/DVD player where you can output the signal with RCA/composite cables. Basically, use your VCR/DVD player as a tuner for your TV.
Posted on Sep 20, 2008
How to hook up antenna to rca p46924
Just follow the cable hook up against the hookup on your tv. The antenna should be hooked up to an output labeled cable in.
Apr 02, 2014 | RCA P46924 46" Rear Projection Television
Connect to a cable box rca e13334wh
see the hookup for this tv and fix it. God bless you330538e7-fbfc-4817-9c8a-19a6a95227e3.jpeg
Jul 10, 2013 | RCA E13334WH 13" TV
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Where is the cable or antenna hookup located
The only cable or antenna hookup on any tv is the f-81 connector on the back or side. Its silver and you screw the cable on. Alot of new tv's dont have them especially the ones that are considered monitors. If that is the case you can get a reasonably priced rca adapter from and electronic store. What it does is the cable goes into to it and the red white and yellow cables will run to your tv.
Aug 22, 2009 | Televison & Video
Tuner end broke off in the back of tv the cable/antenna connect
im afraid not if your good with a soldering ion you should be able to bodge something otherwise take it to your local tv shop they should be able to help.
Mar 07, 2009 | RCA HD52W58 52" TV
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
Sep 27, 2008 | Televison & Video
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
XM Sure Connect antenna assembly.
You didn't say which type of vehicle your wife drives, so here is a generic answer, Good luck (my wife loves her Sat Radio!)
By the way did you get any reception without the kit?
The SureConnect cables plug into the vehicle dock antenna plug and the XM antenna then plugs into the SureConnect cable. The SureConnect cable cannot be used on a retractable or motorized antenna.
If you cannot use the cable, at all, then I would go to Crutchfield, via the phone or web, as they have good technical advice. You may need a different adapter. Possibly part # 040SA10112.
Crutchfield # 1-888-955-6000
Dec 31, 2007 | Audio Players & Recorders
RCA D56W20 56" Rear Projection Television Logo
107 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
