Question about Lexmark Color JetPrinter Z52 InkJet
Lexmark Z52 won't feed paper
My Lexmark Z52 won't feed paper. The feeder spins, but it won't grab the paper and move it until I push each sheet about an inch down and then it grabs. I cant tell if the texture of the wheel that spins against the paper has become too smooth, or maybe it's not pressing firmly enough against the paper, like maybe a spring is no longer tight enough. I am determined this this is not going to hit the landfill! Are feeders easy to replace? If so, where would I get one for my not-brand-new printer?
  • Anonymous Oct 04, 2008
    Exactly the same behaviour !
  • Anonymous Mar 09, 2009
    Mine is doing this too, and I just bought new cartridges. Grrrr. Don't want to have to replace the printer if I don't have to.
    Habit-Forming:
    New Friend:
  • 26 Answers
You can try to clean it by using a blower maybe there are some debris stuck on the paper feeder assembly. But if its evident that the rubber of the paper feeder is worn out already then probably needs a replacement. but this parts are sold as one assembly it might cost you a lot.
Posted on May 23, 2017
Roop1980
  • 228 Answers
SOURCE: My printer won't feed the paper through. the
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned.
Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Turn the printer ON.
2. Press the down arrow button till the screen displays “Maintenance". .
3. Press the "Check" button.
4. Press the "Down arrow" button till the screen displays “Print Test Page.”
5. Press the "Check" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed.  If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Posted on Oct 02, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Feeder is no longer feeding. What should be
    Well I don't think you are going to be able to find replacement parts for it. But what you can do is try the following. Turn off the printer, unplug the power cord, remove any paper that you may have in the feeder now pick up the printer and flip it upside down. Be careful with the scanner lid but sometimes what happens is that things will get inside the printer blocking the paper path. That will cause the printer not to pick up the paper most of the time.
    Posted on Jan 13, 2010
    • 64 Answers
    SOURCE: Paper will not feed. Sounds like the mechanism is
    Maybe the problem is,the problem is with the mechanical paper grabbers inability to grab this type of paper.
    Posted on Feb 15, 2010
    yammy_alf
    • 666 Answers
    SOURCE: The paper won't feed through my Lexmark Z52
    try to replace feed roller might that roller already worn out.
    Posted on Apr 05, 2010
    Joed911
    • 4338 Answers
    SOURCE: How do I fix the automatic document feeder on my
    Lift the ADF cover and clean the rollers with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Posted on Aug 01, 2011
    Testimonial: "After cleaning w/ the soap/alcohol mixture the paper still jammed. I gently pushed the paper through the rollers manually & removed a jammed sticker."
    Lexmark X4530 won't load paper to copy
    Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
    1. Remove the sheets of paper from the feeder.
    2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
    3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
    4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
    5. Check the cartridge area for any obstructions in the paper path.
    6. Close the printer cover.
    7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
    8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
    Mar 16, 2012 | Lexmark Office Equipment & Supplies
    My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
    Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
    3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
    4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
    5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
    6. If cartridge area is clear, close the cover.
    7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
    8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
    If problem continues, please contact Lexmark Technical Support Center for additional assistance.
    Sep 03, 2011 | Lexmark X2600 InkJet Printer
    Lexmark X85 won't feed paper. When trying to
    There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
    2. Grab a flashlight and look inside for any debris.
    5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
    7. Unplug and re-plug the printer into the power outlet to reset it.
    8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
    ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
    7. Close the printer cover and check for any errors.
    8. If no error appears, reinsert the other cartridge. Close the printer cover.
    9. Replace whichever cartridge is causing the error to appear with a new cartridge.
    Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
    When trying to print the paper won't feed through. It will on the left side (looking at the front of the printer) but won't on the right preventing it to print. I just bought and replaced both...
    There could be something blocking the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder. Make sure there are foreign objects or debris that could cause this problem.
    May 13, 2011 | Lexmark X4650 InkJet Printer
    Paper feeds over 50% into printer, makes noises an stops. When I try to see the paper by lifting the lid, it's not there. It's as if its feeding into another area of the printer
    One of the leading causes of paper jams is some sort of debris falling into the feeder. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any foreign objects. If you're willing and capable, carefully lift your printer upside down. Any debris should just freely roll out from the feeder.
    Apr 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
    I have a P915 printer that even though there is paper loaded and no paper jam the paper won't feed. It will start to run and the message "add paper" appears. It appears the "feeder...
    There could be some sort of foreign objects that fell into the paper feed system. Remove the sheets of paper from the printer. Grab a flashlight and look into the feeder for any debris. If you are capable and willing, you may carefully turn the printer upside down so any foreign objects will just freely roll out from the feeder.
    Re-seating your cartridges may also help resolve the problem. Remove and properly reinsert your cartridges in the cartridge carrier. Turn off/on your printer to reset it.
    Apr 15, 2011 | Lexmark P915 InkJet Photo Printer
    Lexmark x2350 all in one. paper will not feed
    One of the leading causes of paper not feeding issues is some sort of foreign objects or debris falling into the paper feed system. Remove the sheets of paper. Grab a flashlight and look into the feeder for any debris. If you are willing and capable, carefully lift the printer upside down. Any debris should just freely roll out from the feeder.
    Apr 12, 2011 | Lexmark X2350 All-In-One InkJet Printer
    Paper will not feed into the printer, not even if I help it.
    Suggestion, but not the answer.... Mine has same problem. I have to feed 1 sheet at a time. If the sheet is too high or too low, it won't work. Put 1 sheet in feeder, then gently push it down until it's 3/4" below the top of the feeder tray. Any higher and it won't grab, any lower and get jam message. What a pain! Finally bought wife a new printer and use this one for 'playing' and faxes. Bob
    Sep 24, 2010 | Lexmark X5470 All-In-One InkJet Printer
    Label sheets won't feed, jam
    1. Turn the printer off and open the access cover.
    2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
    3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
    4. Watch the paper as it feeds through and try to determine where the jam is occurring.
    5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
    6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
    7. Turn the printer off.
    8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
    9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
    good luck..
    Dec 22, 2008 | Lexmark Z845 InkJet Printer
    Lexmark Color JetPrinter Z52 InkJet Logo
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
