Question about Microsoft Wireless Optical Notebook Mouse 4000
Wireless mouse My wireless mouse no longer connects. My batteries are good.
    President:
  • 8,637 Answers
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 22, 2009
Wireless mouse pa3706e-1et1 no longer operates my computer even though new battery installed and software re-installed.
Aside from the fact that the mouse may have gone bad, have you tried pushing the "connect" button on the bottom of the mouse? Also, is the battery in correctly?
Change the USB port to see if that helps.
May 19, 2011 | Toshiba Wireless Mouse PA3205U-1ETC
I have a logitech wireless mouse and keyboard (7 months old)- I recently moved my computer and when I hooked verythign back up it no longer works- I have tried everything from restarting, plugging the...
Underneath the mouse and the keyboard will be buttons labeled "Connect", you will need to resync with the receiver plugged into your computer. Press the connect button on each device in turn and it will attempt to resync.
If this does not work the next thing is to test with fresh batteries, however it is unlikely that both the keyboard and the mouse would run out at the same time.
Finally try with the receiver right next to the keyboard/mouse, sometimes other devices can interfere with wireless signals (WiFi networks, microwaves, vacuum cleaners etc...).
Feb 28, 2011 | Logitech Cordless EX 100 Mouse
My wireless mouse wont work
The wireless mouse functions with batteries. Snap open the location area at buttom of mouse to either check for misalligned batteries or dead batteries requiring replacement. Also, the wireless mouse has an adpater cable that is connected to the computer USB area from where signals are acquired during functionality. Make sure every connectable cables to the computer are firmly in place. Sometimes, the computer may require restarting to capture wireless establishments if an disconnections were encountered once computer was still on. Make sure every connectables are firmly in place, restart the computer for desired functionality. Also, a restart of the computer should diagnose the malfunction of mouse attachements. Improtant notes: A new wireless mouse may have required installation of softwares, opening the computer wireless devices estblihment area to regulate captions on the new setup priop to first acquisition of wireless mouse functionality. Good luck
Jan 11, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
Wireless mouse stopped working.
Unplug the wireless receiver from the back of the computer. Wait 10 seconds and replug back in. Check connectivity. If nothing then check batteries in mouse, if still nothing try click the Connect button on the wireless receiever and then underneath the keyboard...repaet the process for the mouse. You should get something on the screen stating the channel 1 is for the keyboard and channel 2 is for the mouse. Hope this helps! - Erick :-)
Dec 19, 2009 | Microsoft Wireless Laser Desktop 4000...
Optical mouse no longer works
I doubt the problem is the battery, and you do NOT have to press the Connect button each time you use the mouse - it will connect all by itself if it can. The Connect button is only used to re-establish connection if for some reason it cannot connect automatically.
I have this same mouse and it has worked beautifully for two years now EXCEPT for one problem: most of the time, the mouse does not turn on when the receiver is removed from the receptacle on the bottom of the mouse. There is a tiny little switch built into that receptacle, along the side wall of the receptacle not far from the light, so that it gets pressed when the receiver is inside the receptacle. I have to wiggle this little switch (gently!) by hand a few times until the light comes on. From that point, the mouse will work fine until the receiver is placed back in the receptacle.
Nov 05, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless laser mouse stopped working. KB OK. Tried Everything
Under the mouse near the optical lens there should be a small connect button, press that and the button on the receiver too.
Also make sure the batteries in the mouse are new or fully charged.
Good luck
Jun 28, 2009 | Logitech Cordless Mouse
Wireless mouse model 3000 no longer works. I cleaned battery corrosion off and no luck. any ideas?
change the batteries and press the button on the back of the mouse called connect to get it resynchronized.if it still doesnt work then u have to buy a new one
May 13, 2009 | Microsoft Wireless Notebook Optical Mouse...
Apple wireless mouse no longer connects
please remove the battery and check the mouse with saperate good battery also.update the mac os x with the latest avilable update.and update the bluetooth drive for mac.the issue will get solve
Oct 27, 2008 | Apple (ABT-M9269ZA)
Unable to connect to the synaptics pointing device driver
I am assuming that the mouse has batteries installed in it and the CD was used to install the software program for the mouse.
Did you try Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Sep 08, 2008 | Microsoft Wireless IntelliMouse Explorer
Microsoft Wireless Optical Notebook Mouse 4000 Logo
307 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
