SOURCE: more compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
SOURCE: upgrade compatibility continued
hiya
as this pc is skt 775 and has dual core support then it is quite likely that the e5200 will work but may need a bios update to support this cpu...
just goto dells site and choose the pc u have and select drivers then download the lastest bios, transfer it to the dell pc run it as its a self extractor system will reboot perform the update then bobs ya uncle.......pop in new cpu and hey presto cheapo ugrado
#and as for the graphics card you will need to accertain which pcie version u have as most dell pc's only have pcie v1 so wont be able to handle the newer gpu's on the market.......
hope this helps
Rik
SOURCE: new graphic card for Evesham Axis 64 3200
Are you asking about upgrading your graphics card?
Aslong as you get a graphics card that is AGP connection you will be fine.
They dont make AGP graphics cards anymore, but one of the last ones made (and most powerful is the Nvidia 7950 AGP) can be found all over ebay.
Its not a cheap card though, and a later edition nvidia 6 card would be just as good for you, such as an Nvidia 6800 AGP graphics card
• HyperTransport 1.0 supporting speed up to 1000MT/s
Chipset
• NVIDIA® nForce 630a & GeForce 7025 chipset
Main Memory
• Supports Dual Channel DDR2 667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
- Supports a maximum memory size up to 8GB.
Slots
• One PCI Express 1.0 x16 slot.
• One PCI Express 1.0 x1 slot.
• Two PCI slots (support 3.3v/5v PCI bus interface).
On-Board IDE
• One IDE port by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• Two SATA II ports by NVIDIA® nForce 630a & GeForce 7025 chipset
- Supports storage and data transfers at up to 3Gb/s
RAID Function
- SATA II 1~2 supports RAID 0, 1 mode by NVIDIA® nForce 630a & GeForce 7025 chipset
