Question about Gateway MX3560 Notebook
Wi Fi My brother's notebook suddenly lost wireless connection. He uses Win XP, and in 'Control Pannel" there is no 'Wireless Connection" icon. There is only LAN connection icon. Also the computer cannot sense or locate availability of wireless accesses. Whe I see in Device Manager, a wireless device one other are marked with yellow exclamation mark. What is the problem? If I want to dowload drivers, how can I identify the right one? Can I download using another PC that uses Vista and copy it safely to the affected computer? Please help.
  • egeree Sep 20, 2008
    Thanks my friend. I will try it the way you suggested and post the result.
    But one more question: That affected notebook of my brother does not connect to internet as Wi Fi failed. I have my own but I use Win Vista while the effected computer uses Win XP. Can I download the driver with my computer (to HDD or flashh drive) and transfer it to the affected computer?
    Sergeant:
    Champion:
  • 258 Answers
The wifi driver has malfunctioned reinstall the driver to find the appropriate driver for that by right clicking on the yellow exclamation then copy the details of the driver then you can search the driver in the manufacturers site or in drivercollection.com
thanks for posting
Posted on Sep 20, 2008
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
How do I turn on an acer aspire wireless switch?
Sony's Sony Vaio laptop features built-in wireless LAN adapter that allows the computer to connect to any wireless access point. If you want to adjust the device's WiFi settings, you must use the proprietary software and hardware that comes preinstalled on the laptop and the Internet connection options that come with Windows. Once you have all of the correct settings enabled, you can have your laptop connected to a wireless access point without any additional applications.
Enabling Wi-Fi with Wireless LAN Switch b> Before you can connect to a wireless network or change any of your Wi-Fi settings, you must first enable the computer's Wi-Fi feature with the wireless LAN switch. This switch is located directly below the laptop's screen and is labeled "Wireless." Once you have located the switch, slide it into the "ON" position. b> Enable Wi-Fi in Vaio Smart Network b> Once Wi-Fi has been enabled with the wireless LAN switch, you must enable Wi-Fi using the laptop's proprietary wireless connection software, "Vaio Smart Network." To access this program, click the "Start" button in the computer's task bar and select the "All Programs" option. Select the "VAIO Smart Network" option to launch the program. Alternatively, you can click the VAIO Smart Network icon in the computer's task bar to launch the program. This icon is in the shape of a green button with two white arrows on it. Once in the application, click the switch to the right of the "Wi-Fi" heading to toggle it to the "ON" position. Windows Connect to a Network b> With Wi-Fi enabled, you must connect to the wireless network using the "Connect to a Network" feature that is a part of the Windows operating system. Click the network icon in the computer's task bar to bring up a list of the available wireless networks. This icon is in the shape of a computer and an Ethernet cable if you not connected to a network. If you are connected to a network, it is in the shape of signal bars. Select the desired wireless network from the menu that appears and select the "Connect" option. Enter the networks password if necessary and connect to the network. b> Network and Sharing Center b> If the wireless network that you want to connect to does not appear in the "Connect to a Network" window, you must connect to the network manually. Click the network icon in the computer's task bar and select the "Open Network and Sharing Center" option. Click the "Manage wireless networks" option, followed by the "Add" option. Click the "Manually create a network profile" option and type the network's information in the spaces provided. Place a checkmark next to the "Start this connection automatically" option and click the "Next" button to connect to the network.
b>
Feb 08, 2013 | Sony VAIO VGN-AR150G Notebook
Will not connect to wifi network
Hope this helps
Nov 11, 2012 | Sony VAIO VGN-N325E Notebook
Lost wi fi connection to our wireless network, tablet displays "turning off" under the wi fi settings.
I suggest to reinstall the wireless card driver first ..just in case, this will solve any driver issues and will make it functional in case the driver or the setting are corrupted..
To download the driver in case you do not have it on disk or saved somewhere ..just go to acer.com ...select downloads ...drivers and select the model and operation system you use..
download the wifi driver ..run it again ..and after that restart ..and try to make the connection again ...Check the wireless card in device manager to see if it shows in order ...and did not appear in yellow which indicates driver related issues..
also be sure you have network signal ..and the router is functional ..in case other computer is working with this network ..check to see if the connection actually works ..
To redo the connection ..just open the settings for wireless...and click scan for networks ...In the list of available connections ..select yours..and click connect ..insert password if needed.
Good luck !
Nov 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
My notebook cannot connect to the wireless router. its on my wifi but i cannot connect to the internet. it says dns server error
Hi Dear Being able to connect to a wireless network or wi-fi hotspot is fundamental for mobile work and play. The step by step directions in the wi-fi tutorial below will help you set up your laptop so you can connect to a network wirelessly for Internet access or to share files with other computers on the network. Examples are given for Windows XP, Vista/7, and Mac.
  1. Find the wireless network icon on your computer (on Windows, you'll find an icon that looks like 2 computers in your taskbar on the bottom right; Macs will have a wireless symbol in the top right).
  2. View available wi-fi networks by either right-clicking the icon and selecting "View Available Wireless Networks" (Windows XP) or left-clicking the icon and selecting to "Connect or disconnect..." (Windows Vista). On Mac OS X and Windows 7, all you have to do is click on the wi-fi icon to see the list of available networks.
  3. Choose the network to connect to by clicking the "Connect" button (or just selecting it on Win7/Mac).
  4. Enter the security key -- if the wireless network is encrypted (with WEP, WPA or WPA2), you'll be prompted to enter the network password or passphrase. This will be stored for you for next time, so you'll only have to enter it once.
  5. On Windows 7, select the type of network this is -- Windows 7 automatically sets up security for different network location types (Home, Work, or Public).
  6. Start browsing or sharing! You should now be connected to the wi-fi network; open your browser and visit a website to confirm.
Tips:
  1. Make sure you have a firewall and updated antivirus software especially if you're accessing a public wi-fi hotspot. Open or unsecured wireless networks are not safe at all.
  2. In Windows XP, make sure you have updated to SP3 so you have the latest WPA2 security drivers.
  3. Some wireless networks are set up to hide their SSID (or network name); if you don't find the wi-fi network in your list, ask someone at the establishment for the SSID information.
  4. If you are able to connect to the network but not the Internet, make sure your network adapter is set to automatically get its IP address from the router or try other wireless troubleshooting tips.
  5. If you can't find the wireless network icon, try going to your control panel (or system settings) and the network connections section then right-clicking on the Wireless Network Connection to "View Available Wireless Networks". If the wireless network you're looking for isn't in the list, you can manually add it by going to the wireless network connection properties as above and clicking on the selection to add a network. On Macs, click on the wireless icon, then "Join Another Network...". You'll have to enter the network name (SSID) and the security information (e.g., WPA password).
Sep 20, 2011 | D-Link DIR-600 Router
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
Wi-fi connection
1. First, you have to make sure that the Wi-Fi of your laptop is turned on.
2. Make sure that there's an available wireless network in your area so that you can test if the computer can detect any available network.
3. If you're running Win XP, right-click the wireless icon on your system tray and select "View available wireless networks"
4. If you can't detect any wireless network, right-click the wireless icon on your system tray and select Open Network Connections.
5. Right-click the Wireless Network Connection icon and make sure to enable it.
6. If it's already enabled, try to disable it and then re-enable it.
7. If you can't still detect any wireless network, try this:
- Click the Start > Run > type msconfig > hit Enter
8. Locate the Wireless Zero Configuration and click on it once.
9. Once it's highlighted, locate the Start button on the upper left hand corner of that screen.
10. After starting the Wireless Zero Configuration (WZC), try to detect the wireless network again.
Apr 08, 2009 | Advent 4211c Notebook
Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Dec 26, 2008 | Toshiba Satellite M45-S265 Notebook
Gateway PC crashing when connecting to Wi-FI
if i was you i would load up a version of win xp on another hard drive inserted into your laptop, load the drivers for the laptop including wi fi drivers then see if ok. if not you can be sure its a faulty wi fi card in your laptop,you need to disable internal wi fi card remove,replace it.but first try borrow a pcmcia wi fi card just to check if everythings ok
Dec 06, 2008 | Gateway MX6438 Notebook
Wi Fi driver downloading
Yes that should work fine, just as long as you download the driver for his card and his OS.
Sep 21, 2008 | Computers & Internet
Open Questions:
Motherboard Repalcement I have a laptop - Details of the laptop: Gateway MX3560(model) serial # N625AC1052628 ( on the back of the laptop) Motherboard part number # 103501(required item) The motherboard of this got damaged and is not available.So, i wanna know, can i replace it with any other motheboard type - if there is any other motherboard which is compatible with this type.IF yes, please inform me as i am really worried about it. Other details are as follows - Processor Intel® Centrino? Mobile Technology with Intel® Pentium® M Processor 735 (2 MB L2 Cache | 1.70 GHz | 400 MHz FSB) Chipset Intel® 855GM Screen 14-inch Widescreen Ultrabright WXGA TFT Memory 512 MB DDR (1 × 512 MB) SODIMM (PC2700) Expandable to 1.5 GB Video Intel® Extreme 2 Graphics 32 MB Shared Video Memory Audio AC '97 2.3 Compliant Audio Built-in Stereo Speakers Hard Drive 80 GB HDD (4200 RPM) Optical Drive DVD +/- RW Multi-Format Double Layer Write maximum: 8X DVD +/-R, 4X DVD +/- RW, 2.4X DVD+R DL, 24X CD-R and 10X CD-RW disks Reads maximum: 8X DVD-ROM, 8X DL/+RW, 24X CD-ROM disks Media Reader 4-in-1 Digital Media Manager Secure Digital, Memory Stick, Memory Stick-Pro, and MMC Modem 56K ITU V.90 Fax/Modem Network Intel® PRO/Wireless LAN 802.11g SecureEasySetup? 10/100Mbps built-in Ethernet Pointing Device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces 3 - USB 2.0 Ports 1 - IEEE 1394 port 1 - VGA External Connector 1 - RJ11 1 - RJ45 Microphone In Headphone / Audio Out Battery 6-cell Lithium-ion Dimensions 1.24-inches H × 13-inches W × 9.7-inches D Weight 5.24 pounds
Jan 07, 2009 | Gateway MX3560 Notebook
Gateway MX3560 Notebook Logo
155 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
