Question about Cameras
Deleted pictures I accidentally deleted pictures from my PowerShot A620. Can I get them back?
  • heljam Sep 21, 2008
    Do you know of any free software for macs? I have a macbook.
You can use camera photo recovery software, download from
How to recover deleted photos from digital camera
helped me last time, hope that it helps you also.
Here's another one
http://forum.001-software.com/pbb/viewtopic.php?f=4&t=11
I found the post while searching, but didn't try it myself. You may try it.
Posted on Jul 12, 2015
    President:
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Posted on Sep 21, 2008
How do you set the timer delay to take a picture of yourself a620 powershot
From the menu, select Drive Mode (third item from the top) then one of the self-timer options. Start the self-timer by pressing the shutter release button.
Sep 05, 2009 | Canon PowerShot A620 Digital Camera
I have a PowerShot A620 and I accidentally deleted pictures I didn't mean to. I'm pretty sure no, but is there any way I can get them back?
You can get back by using recovery software .
Such as file recovery will work .
If you need software . Let me know
SAM ANDERSON
Sep 20, 2008 | Cameras
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Screen is black while taking picture.
Think that you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jul 25, 2009 | Canon PowerShot A620 Digital Camera
Cannon Powershot A-620 black screen can't review
Did you accidentally press the DISP or DISPLAY button on the back of your camera? This manually turns the screen on and off to save batteries. You would then use the optical viewfinder to take pictures. To turn the screen back on, just press this button one more time.
Jul 23, 2009 | Canon Cameras
Screen will not read lense
Sounds like you accidentally pressed the DISP or DISPLAY button on the back. This manually turns the screen on/off to save batteries. Just press it one more time to turn it back on.
Apr 25, 2009 | Canon Cameras
Powershot A620 Zoom Lever
Remove your batteries and look inside the battery compartment. Notice that there should be three small phillips screws at the bottom of the compartment. Tighten up all of these screws.
May 12, 2008 | Canon PowerShot A620 Digital Camera
Blurred pictures with A620
Does it zoom ok? If so the AF motor has got stuck. Same old compact camera zoom lens problem.. buy an SLR.
Dec 05, 2007 | Canon PowerShot A620 Digital Camera
Cameras Logo
154 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
