Zanussi Electrolux FX 1265 W washing machine wont work
The "End" indicator is flashing and cheeping 4 times in a row. Accoring to the manual this means that the door is open, but door is shut fine.
Cant get new programme to start even if I reset programme by moving programme dial back to 0 first.
Dont know if it is relevant but the power circuit which this is plugged into fused last night - though now working fine
  • Anonymous Mar 11, 2009
    Door is shut and sealed, however the led alarm on the end display is lit and there are 4 audible beeps. Which according to the manual indicate that the door is open!
    Any ideas??
  • 116 Answers
Chrisbounty
also not ure what you meant by fused did you have some kind of electrical arcing sparking wires melting?
Posted on Sep 20, 2008
Zanussi washing machine pause button flashing machine wont work iz141s
Disconnecting the wires from the main PCB helped resolve half the problem, but the machine still does not rinse and spin. Unless programmed manually. Still, that's easily done at the end of a wash cycle. Is liveble.
Jul 24, 2012 | Zanussi ZWF1440 Front Load Washer
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Zanussi washing machine drum will not go round at all
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Apr 08, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi FX 1265 W, Aquacycle 1200 Door Problem, won't lock.
take a look at this link.
I have found that a lot of front loaders use the same control board manufacturer with the same solder failure issue.
try the section where you pull up on the white connecter with black wires as it is the easiest to verify the issue
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Feb 02, 2008 | Washing Machines
Zanussi FX 1265 W washing machine
You can seal the cap by some tape, but it is better to get a good replacement, for the filter needs periodic maintenance. Your machine will not drain well if the filter is clogged.
Nov 09, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Washer will not work
Possible drain fault, check filter. Regards Advisor
Jan 28, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
403 people viewed this question
Top Washing Machines Experts
