Question about Frigidaire CWS3600AS Top Load Washer
Frigidaire washing machine top load. troubleshoot
Water draining on floor sometimes. Tub appears to be off balance or more to one side. Frigidaire top load
  • Anonymous Mar 24, 2014
    clogged drain hole filter frigidaire fws933fs, water leaking on floor
  • 116 Answers
There are levelers at the corners of the unit for levelng - tubs have springs attached to them for righting the tub while working (spinning, agitating) - also if the clothes are evenly distrbuted in tub it will wobble badly during operation.
Leaking is usually from the drain pump especially from the point whwere the hose is attached to the pump
Regards
Posted on Sep 20, 2008
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My washing machine will not fill up with water. The water is running into the machine but never fills the machine. It seems like it is just running directly out again. I own a frigidaire top loading...
The drain hose must be higher than the tub. Had the drain hose at any point been lowered or dropped in such a way that it would be below the tub?
Dec 22, 2009 | Washing Machines
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Frigidaire fwx833as2 getting water on floor in wash cycle
Actually there are three fairly common causes for this:
The machine may not be properly leveled, and will go out of balance when spinning, no matter how carefully you load it. The drum tilts to one side and sloshes over the gasket at the top.
The pump might be blocked up badly, causing the water to not drain adequately, which can cause the water to be forced upward and out due to the building centrifugal force. These machines are designed to drain as they spin at a fairly steady rate. If something interferes with the draining, but doesn't slow the spin down, this can result.
Finally, the maximum water level switch (sometimes also called an overflow prevention switch, among other names depending on manufacturer) may be faulty. Normally your water level is controlled by the load size selector. However, on some machines the maximum load size setting is actually limited only by the overflow prevention switch. If yours is one of those, this could explain your problem.
Feb 07, 2009 | Frigidaire Washing Machines
Fridgidaire Washer wont drain
If lid lock is bad the tub will not spin properly. Unplug, remove front and look at the lid lock closely. Let me know, Thanks, Sea Breeze
Jan 08, 2009 | Frigidaire GLWS1233A Top Load Washer
Frigidaire Gallery Model FWT449GF Tub issue
level and balance is very important for all machines. make sure it is firmly seated on floor and shipping bolts pins and brackets are removed (some have brackets inside.) the machine should be able to evenly distribute the load. finally the shock absorbers could be bad. (seems rare on frigidaire)
Mar 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
138 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
