Error code 80072ee7 - Computers & Internet
  • sweetsuicide Mar 15, 2009
    errrr i have another problem about that when i go into advance setting there are no boxes that i can tick o.O there are only buttons that i can click that say "TEST" soo what do i do now?? o.O
    thank-youh
    Problem Solver:
  • 15 Answers
This error occurs when you are not connected to the internet, check your internet connection and make sure it is working properly.
The most likely cause for this problem is that your firewall does not allow Messenger to access the internet. This happens often if you install a new version of Messenger. Make sure Messenger is allowed access in your firewall rules. See our article on using Messenger through a firewall application.
This error might also occur if a proxy server is enabled in Messenger or Internet Explorer while you do not use one. To remove the proxy settings, click the "Tools" menu and then "Options..." at your Messenger main window. Then in the options screen click "Connection" in the list to the left. Next, click the "Advanced Settings..." button. You can try and uncheck all checkboxes in this screen except the one labeled "TCP" to let Messenger connect through a direct connection. If that does not work you can restore the settings again by checking the boxes you unchecked before.
Source
Please rate this solution.
Posted on Sep 20, 2008
Windows update never works! code: 80072ee7
>http://support.microsoft.com/kb/971058 A fix for windows update.
>or if that doesn't work go to the start menu, go to RUN and copy and paste this and hit ok
%SYSTEMROOT%\SYSTEM32\REGSVR32.EXE %SYSTEMROOT%\SYSTEM32\WUAUENG.DLL
Jun 17, 2011 | Computers & Internet
Error code 80072ee7
download reg in out registry cleaner to solve this issue because it is registry error
Sep 09, 2010 | Microsoft Windows Live Messanger
Error code 80072ee7 gateway non in linea
Error code explanation and possible solution This error occurs when you are not connected to the internet, check your internet connection and make sure it is working properly. The most likely cause for this problem is that your firewall does not allow Messenger to access the internet. This happens often if you install a new version of Messenger. Make sure Messenger is allowed access in your firewall rules. See our article on using Messenger through a firewall application. This error might also occur if a proxy server is enabled in Messenger or Internet Explorer while you do not use one. To remove the proxy settings, click the "Tools" menu and then "Options..." at your Messenger main window. Then in the options screen click "Connection" in the list to the left. Next, click the "Advanced Settings..." button. You can try and uncheck all checkboxes in this screen except the one labeled "TCP" to let Messenger connect through a direct connection. If that does not work you can restore the settings again by checking the boxes you unchecked before.
Apr 17, 2010 | Microsoft Windows XP Home Edition
Error 80072ee7
  • Click Start, All Programs, Accessories.
  • Right-click the entry Command Prompt, and choose Run as administrator from the appearing context menu.
  • When Windows asks for your consent, click Continue.
  • Type the following line, and press Enter:
    ipconfig /release
    ipconfig /renew
  • Close the window.
  • Retry to sign in to Messenger.
Jan 24, 2010 | Microsoft MSN Messenger Connect Service
Connection problem
Dec 21, 2009 | Computers & Internet
Error code 80072ee7, my gateway is offline
i want a soluion for error code 80072ee7 in windows live messenger
Aug 19, 2008 | Computers & Internet
Computers & Internet Logo
504 people viewed this question
David Payne
David Payne
