Question about Ryobi 30 Cubic Centimeter Gas Brush Cutter
Changing the spool trimmer - 3046YE
Do not have a manual
Can anyone help please
Cheers
Carl
Pcb 3046ye machine starts idles too fast touch throttle then cuts
Hi Ronald,
Not a lot to go on here.
If you are serious about getting an answer, include Make and Model. Describe your problem clearly, concisely and with as much detail as possible.
Often, a problem can be the result of a seemingly unrelated event. It is always a good idea to include a recent history.
Additional information such as what steps have already been taken, has the product ever worked, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
Remember, you are a key participant in this process. I am not there, you are. I depend on you to be my eyes and ears. I can only respond to what you provide me.
What you get out of the experience depends on what you put in to it.
So help me help you.
Best regards
Mike
Jul 12, 2010 | Ryobi Three Trimmer Combo
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Stihl fs trimmer line fitting how to fit line to trimmer can you help anyone
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
If you need more help, let me know.
Jim
Nov 20, 2009 | Garden
Trimmer line on spool of Challenge 250 Watt Grass Trimmer.will not automatically feed as it is supposed to do when tapped on firm surface - can you let me see by diagram how the line is feed onto spool and...
I did a lot of searching for a manual but I guess Argos does not want their customers to know how to use their product. When you are use the trimmer, most rotate clockwise. You may find on the spool an arrow showing direction to wind line. Otherwise you will have to take it apart the trimmer and remember with direction the spool turns. Wind the string on the same direction turns. plus try a little wd40 on the line to keep it from sticking together.
Cheers.
Oct 12, 2009 | Garden
How do you add trimmer line to Troy Bilt TB539E Weed Eater?
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
Sep 07, 2009 | Garden
How do you take the spool off the Homelite gas grass trimmer?
Push in on the spool & turn counter clockwise. This works for most trimmers. Careful though, the center spring may pop off with the spool. (I wouldn't do it on a hill)
Aug 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
How can I open the spool for line replacement? Please help
Just push the bottom of the weed wacker in and turn to the left the spool should fall out if u need anymore answers just ask
Cheers
Johnthetr870
May 15, 2009 | Garden
Ryobi 30 Cubic Centimeter Gas Brush Cutter Logo
207 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
