Question about Nu Mark Numark Dxm01 DJ Mixer With Two USB Connections System
Pc connection how to connect bontempi keyboard to pc
  • patrick364 Sep 20, 2008
    done that but nothing showing on pc do i need a driver
Why does my wireless keyboard not connect when the mouse does
Broken keyboard, or the USB in pc is fault, try another USB hole or get a refund for the keyboard.
Oct 15, 2010 | Computers & Internet
Broken volume pedal on bontempi 24110008 organ.pedal wont stay in up position.
There MAY be a counterbalance spring that is missing or broken AND there HAS to be a friction device to hold the position. You should be able to remove the pedal assembly to analyze and repair it.
It may involve just tightening whatever is suppose to create the friction to hold the pedal.
Apr 24, 2010 | Music
How to play minor chords on Bontempi MS40?
easy:
- the lowest key gives the chord C for C major (do majeur)
- add a key on the right (up) for exemample D or E or (it doesn't a matter) gives you the minor chord.. (here Cm = do mineur)
- add a third one ( always on the right side) gives you the 7 here C7 (do septieme)
enjoy!
what a pity we can't easily disable this auto chord function in orfer to get real notes for the left hand!!!
Jan 22, 2010 | Bontempi Toys
Sony vaio vgc-lv1s keyboard and mouse not connecting
Disconnect all devices from your PC including usb mouse and power adaptor.
Press power button and hold it for 20 seconds.
This will statically discharge teh PC. THen take out batteries from the keyboard and pres connect button to discharge keyboard.
When this is done connect pc to the mains and turn it on
Put batteries into keyboard and try to connect.
Press connect button on the pc first and then within few seconds press connect button on the keyboard.
Please leave your feedback if issue is solved or you need futher assistance
May 28, 2009 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
Sony VGP-WKB5 VAIO Wireless Keyboard unable to connect
May 28, 2009 | Sony VAIO VGP-WKB1 Keyboard
Can't wake the computer
Probably there is no connection between your keyboard and mouse to the CPU. Check for proper connection of your keyboard and mouse. If the connection is good, probably there is the problem with the cord that is connected with your mouse or keyboard.
Turn off first your PC before making any connections.
After you confirmed that there is no problem with the connection, probably the problem is at your mouse or the keyboard itself.
Apr 21, 2009 | E-Machines eMachines Desktop PC
Sony PCV-V210P PC with PCVA-KB6/U computer and wireless keyboard
Press the CONNECT buttons located on the left panel of the computer and then press the connect button on the bottom of the keyboard, to establish communication.
Aug 05, 2008 | Sony VAIO PCV-V210P PC Desktop
Nu Mark Numark Dxm01 DJ Mixer With Two USB Connections System Logo
32 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
