Question about Refrigerators
Whirlpool arc 7720
Hi, constantly being having problems with build-up of ice in back of freezer, resulting in having to use hairdryer on regular basis, i today tested the heater using a multi tester and got positive result of 25-30, however there is a plastic tubing containing numerous wires at back of freezer beside the fan, which works fine, however the two wires that connect to the heater(blue/white & black) gave a negative reading, do these wires run to the timer and if so where is it located, so just to clarify the blue/white & black wires that come fitted as standard on the heater are showing a positive reading but two wires that plug into the heater are showing negative reading, any advice would be much appreciated, many thanks Stewart
  • 725 Answers
SOURCE: my amana scd23vbw
first do you have any heat from the compressor ? ( back bottom of the fridge) is the evaporator fan running. let me know and I can help..
Posted on Sep 05, 2007
  • 3422 Answers
SOURCE: whirlpool et1chmxkt03
You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Please don't forget to rate the solution.
Posted on Mar 30, 2008
  • 247 Answers
SOURCE: evaporator fan jams with ice buildup from drain
Could be that, or it could be the temperature sensor on the evaporator - if that goes, then as soon as the freezer starts a defrost cycle, it will think it's got the evaporator hot enough and will start cooling again.
Suggest you let the freezer thaw out then, with a voltmeter connected across the terminals on the board which connect to the sensor, turn the freezer on and see if the sensor reacts sensibly to the evaporator cooling down. It's usually done with a thermistor, but just for the moment, I can't remember whether it's usually a PTC or an NTC.
That way, if it is the sensor, you'll be spared the expense of replacing a serviceable pcb.
Posted on Apr 13, 2008
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
  • 64 Answers
SOURCE: Need photo of Defrost Switch or Sensor
Unit needs to be cold when you test. it closes at around 20 or 30 degrees F and opens around 55 deg F
Posted on Jul 02, 2009
Water is dripping down the back of the refrigerator inside and pool in the bottom of the refrigerator. Whirlpool/ freezer on top ET-1CHMXKQ02. Freezer is still working and icemaker is still making ice.
Defrost drain tube is clogged. Have to clear this by removing back wall inside freezer and removing the ice build up inside the defrost tray and tube. Very very hot water and hairdryer will help with this process. hope this helps.
Jan 28, 2010 | Whirlpool 21.6 cu. ft. Top Freezer...
Freezer runs constantly and ices up
It sounds like the thermostat has failed. Have it replaced and it should take care of your problem. Hope this helps, good luck!
Sep 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Side by sise refrid freezer top is not cooloing on freezer side warm on refergerator side
suspect fan is not working - can you hear fan?
if not, chances are fan is jammed with ice build up. take back panel off inside freezer and if there is ice build up, melt off with a hairdryer. also check for continuity thro fan and make sure it rotates freely
Oct 09, 2008 | Whirlpool Refrigerators
Whirlpool arc 7720
hello stewie,
with that kind of fridge that you got, im pretty sure you got a board defrost. but that's not the only issue here.
if you have ice build-up, three things to look at.
first, the heating element, test for low resistance.( it must be low )
second, the bi-metal, test it while frosted up and it should have continuity. it is in the evaporator attached to a coil. it has two wires in it.
third is your board which controls your defrost cycle. ( very hard to tell if the board is the problem unless there is no problem with first two components stated earlier.)
tnx 4 using fixya,
Sep 16, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Water leak
probably the defrost drain blocked. remove back panel from inside freezer and melt ice off with hairdryer and follow up with hot water till water flows away freely.
you may find all the pipework iced up and if so you have a problem with defrost system.
an alternative way is to switch off for 24 hours and leave doors open
Aug 23, 2008 | Freezers
Freezer cold/fridge not
take back plate off inside freezer and see if there is ice build up on the pipework. if so, this prevents airflow and the fridge is affected first. melt off ice with a hairdryer and restart.
if fault reoccurs, you have a fault with the defrost system
Aug 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
