Question about Sharp Audio Players & Recorders
Sharp minidisc player MD-MT161E(S). On putting in disc, the player attempts to read it and then come up with error message TOC3 and switches off. Is this economically fixable or is it a fatal problem?
  • ds014b5296 Sep 20, 2008
    Yes. Though not the news I wanted to hear. Thank you anyway.
  • ds014b5296 Sep 21, 2008
    I now believe that 'TOC' stands for 'Table of Contents'. The error message was wrongly reported by me and should have been 'TOC error a'. Surely, therefore, as the error occurs as the machine is trying to read the contents of a minidisc there is the possibility of the disc conternts being incompatible leading to the erroe message. The subsequent shutdown is, I believe, a normal function of the player.
    Do my comments lead you to revise your opinion,please?
    Genius:
  • 1,550 Answers
This message indicates that there is a software problem in your sharp minidisc player .
The error TOC3 indicates that there is voltage regulation from high voltage to low voltage this causes you to switch off .
It is source code problem you can't repair you need to take to service center .
The cost will be around $100-200 if it is out of warranty .
Thanks for using Fixya
SAM ANDERSON
Posted on Sep 20, 2008
    Brigadier General:
  • 5,158 Answers
Just to clarify one thing.... it completely powers down ?
Robert
  • 1 more comment
  • Roberta Smith
    Roberta Smith Sep 20, 2008
    one other thing.... when you put the lid down for the disk.... hold it gently closed and see if you still get that error
  • Roberta Smith
    and do you get this error with other disks.... sounds like a table of contents error re: reading the disk
    Robert
  • Roberta Smith
    From reading the manual further.... that disk is probably defective.
    Robert
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
Pc minidisk
Google sharp MD-MT280E and download the Users Manual.
Aug 08, 2013 | Sharp MDMT280E Personal MiniDisc Player
I have a mini disc sharp md - ms702. i have not played it much in the past few years. now when i play a disc it plays then an disc error appears. it like it can't read the disc. if i listen to the unit you...
Unfortunately you've done all that you can. The unit is broken and parts are unavailable, even if they were, portable MD players were always fiddly and labour intensive to repair.
It's not all bad news though: as they're obsolete technology there are millions of perfectly good ones lying around unused and unwanted. Every single bit of minidisc equipment which I own has come from my local FreeCycle and Freegle groups, either as a response to an offer or via a request (but note that all such groups usually insist that you must make an offer before you can post a request, but there's no restriction on replying to offers already made).
Sep 02, 2010 | Sharp MD-MS702 Personal MiniDisc Player
MD-MT831 MiniDisc Recorder Error
I've run into the same issue. Have you got it solved yet? In such case, could you please share the solution here? I've tried to enter service mode but with no luck.
Regards,Matt
May 26, 2010 | Sharp MD-MT831 Personal MiniDisc Player
Sharp MD MT-80H(S) not playing sony minidisc 80
I had a similar problem after not using player for several months - "Can't read" message displayed every time I put a recorded minidisc in the player. Seem to have solved it (maybe only temporarily) by opening the player, inserting little finger in at the righthand front and sliding movable mechanism from side to side. It looks to slide on a bar which had maybe picked up dirt or damp. Also tried blowing a warm hairdryer into the slot for a minute or two (take disc out first!) to remove any damp. Working OK at the moment.
Jan 19, 2009 | Sharp MD-MT80H Personal MiniDisc Player
MD Error Message
I'm sorry this isn't much help, but I had the same problem with my 702 unit. From what I've read it's very common with this model - Sharp claims to have remedied the error with their 831 unit. Luckily, when I had this problem, my recorder was still under warranty and I have to say that Sharp fixed it promptly and returned it to me. Have you tried contacting them? Since it's a design flaw, they might be amenable to working something out with you...
May 27, 2008 | Sharp MD-MS702 Personal MiniDisc Player
Sharp minidisc MD-MT20 H - TOC ERROR a
I am sorry to say but your unit needs to be sent for repair. The TOC error shows up when the unit can't read the Table Of Contents of the disc (and simply shuts down after trying)....and in your case, you said it can't read any disc. This indicates that the lens unit has malfunctioned and needs to be repaired or replaced.
Mar 17, 2008 | Sharp MD-MT20 Personal MiniDisc Player
Toc error problem
HEY,
t is not the topic, but I'm for al long time searching for the sharp md-mt20h and I see that you buy a new md player? Were can I buy him?? thanx
Sep 20, 2007 | Sharp MD-MT20 Personal MiniDisc Player
100 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
