Question about Dell Dimension 5100 (D51L1) PC Desktop
Drive 2 and 3 not found
Hello.
i get the following messsage in DOS when I start my computer
Drive 2 not found,parallel ATA,PATA-0 ( PRI IDE Master)
Drive 3 not found,parallel ATA,PATA-1 ( PRI IDE Slave)
Can you help me with this problem.My service warranty expired 3 days before this problem arose and Dell is not willing to assist with this problem.
  • 3 more comments
  • Anonymous Oct 24, 2008
    I keep on receiving the follwoing message "drive 2 not found parallel ATA PATA 0". How to solve this?
    Any help is aprpeciated
  • mhdsalih Nov 12, 2008
    Drive 2 not found: Parallel ATA
    Drive 3 not found: Parallel ATA
  • Tomykat Jan 18, 2009
    The error message and DELL "support"!
    I have tried re-enabling my "drive 2" but with no success.
    All suggestions appreciated.
  • Perfect Ange Jan 28, 2009
    Dell 4700 Series
  • LLYork Apr 19, 2009
    I have the same problem of DRive 2 --- not being found
    any suggestions on how to fix this would be appreciated
    need specifics -- as I am not very literate in fixing these computers
    one response said to go to boot and activate the drive --- how do you do this ????????????????
    It is a Dell Dimension E510 machine @ 3years old
Posted on Sep 23, 2009
Go to boot up and ENABLE the drives
Posted on Oct 10, 2008
What's your problem?a way to turn the SATA ports to ON in the BIOS
You can go into the bios and on those drives that are not found you can turn them OFF or N/A. They are probably set to AUTO or ON.
If that does not work I would say remove the power cord, remove the cover, then remove the main power to the motherboard then plug the main power to the motherboard back it. The main power will run from the power supply and the end of it will be about a 2 inch strip that plugs into the board. Press and hold the little catch on it then pull it out of the socket on the board. Put it back in firmly. Reboot and see what happens.
Apr 04, 2012 | Dell Dimension 4700 PC Desktop
Error Message: Drive 2 not found: Parallel ATA, PATA-0 (PRI IDE MASTER)
Anonymous,
Did you set the jumper on the drive to cable select? Check to what the jumpers on the back of the drive is set to. You should have 3 selections. primary,secondary and cable select.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 21, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
On boot up on my Dimension 3100C I receive the following error message: Drive 1 not found:Parallel ATA, PATA-0 (PRI IDE Master) Alert! chipset heat sink not detected System halted!
first off your going to ewant to hit f2 or f12 to get into setup and you are going to want to change boot oder to your hard drive. i then would open the comoputer up by taking the side of the case off and checking your cpu. u are going to wanna make sure there is a heatsink or fan securly on your cpu. if not this could over heat and burn your cpu up. heat sinks look like thisbadboy616.png
Jan 07, 2011 | Dell Dimension 3100 PC Desktop
What is the slave patern for 500 gig hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Dec 10, 2010 | Western Digital WD Scorpio Blue WD5000BEVT...
On a dell dimension 3100c, i am getting the error when i boot up of Drive 1 not found, parallel ATA, PATA-0 (Pri ide master) When i press F1 the system boots up normally. My hard drive is SATO 0, and...
The DVD drive is having a problem. Ensure the Jumpers are set to Cable Select, and both the data and power cables are seated well
if the drive still doesn't work right, boot to BIOS, turn on caps lock, scroll Lock and num lock, press ALT +E then ALT+F then ALT+B and let the system reboot and re-detect the drives
If still no go, you can try a different drive and or a different cable
May 31, 2010 | Dell Dimension 5100C (D51CL1) PC Desktop
DRIVE 1 NOT FOUND, PATA 0
One of your settings in the BIOS is set to look for a drive and it is not finding it. That is what that message means. If you have multiple drives in this machine then one of them has failed. If you only have one drive then the settings are set to look for a drive and it is not finding it. To fix this reboot the computer. When you see the DELL logo press F2 to get into setup. Then go down to Drives and turn off any drives that are set to Auto, except for your C: drive which should either be SATA 0 or PATA 0. Since it is not saying that SATA 0 is not found then I suspect your main drive is on the SATA 0 channel. Go to SATA 1 and turn it off. The instructions should be on the screen. Usually you select it by moving the arrows and then hit enter, you then use the arrows to select off. If your CD-ROM/DVD ROM is not on PATA 0 then turn it off as well. If you need more advice let me know.
Apr 28, 2009 | Dell Dimension 5100C (D51CL1) PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Mar 15, 2009 | Dell Dimension E521 PC Desktop
IDE Drive not found on startup
I am assuming that the cd and DVD drives are on the Ide right ?? thats because one of the drives jumper is set wrong. If you take a look at the back you will find it saying master / slave / Cable select with eighter a 6 to 10 pins. basically one needs to be set to master and connected with the top piece of the cable and the other set to slave and connected with the middle of the cable. and the other jacks into the main board. If i misunderstood you please respond correcting me as soon as possible so i can be of further help.
Nov 13, 2008 | Dell Dimension E310 PC Desktop
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Dell Dimension 5100 (D51L1) PC Desktop Logo
1,424 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
