Question about Maytag Atlantis MDG6400AW Gas Dryer
Replacing the a drum "fin"
I call them fins because I don't know the official name for them, but they are the tree plastic peices attached to the inside of the drum that tosses the clothes as the drum spins. One came loose and then broke off. It looks like an easy fix. I can get a replacement part, but I'm not sure how to open up the shell for access (the fin needs to be screwed in from outside the drum). Do you have a maintenance manual or instruction on how to open the housing?
    New Friend:
  • 12 Answers
You should be able to Open the top of the Dryer, from front to back, U might need to pry the front corners up with a flat tip screw driver. It should hinge to the back, to expose the Tub... Hope this Helps U...
Posted on Oct 26, 2008
We have a dryer fin with something rattling around in it. Do the fins come off?
Need a model number for the dryer for a more definitive answer--usually you would have to open the top cover to expose the drum. Depending on the model dryer, some baffles(proper name) are screwed onto the drum, some have plastic tabs which must be carefully pushed in order to remove the baffle. Most likely, the rattling is caused by coins left in pockets--they won't damage the dryer but can be irritating to listen to. Front load washers are notorious for trapping coins in the baffles of the rotating baskets--and that is A VERY EXPENSIVE REPAIR if you want to have the coins or objects removed.
Aug 14, 2015 | Dryers
How do you replace the plastic fins inside the drum
You pop the top and use a screwdriver to put the fins back.themobilian_3044.jpg
See the spring clip? Use a putty knife to release the top
Then you can open the door and hold the fin inside while you use a screwdriver to put them pesky fins back in there.
I wrote a page on these
Frigidaire/Gibson/Kelvinator/Westinghouse Dryer Pixthemobilian_3046.jpg
Oct 20, 2011 | Frigidaire Washing Machines
Fin that tumbles clothing inside dryer coming loose, how can I tighten it?
These fins are usually screwed on from the outside of the drum. If you're up to it this is a simple but time consuming fix. Take the cabinet off the front of the dryer, the top will come off as well. be careful of the wires from the control console, they will stay attached to the dryer. Tighten the tumbler fins on the drum and then re-assemble the cabinet. Typically the screws you need to access are the same used for the door latch and hinges. They go back together easy ........
Feb 14, 2011 | Maytag Neptune MDE7500AY Electric Dryer
The chain came off
If your stool has an old style flapper, then the chain would connect to the flush arm at the top and to the little fin on the flapper at the bottom. There should be a little ring connected to the fin. Sometimes the little ring will fall off and go down the drain, then you have to use a peice of wire or whatever you can find. A small clip or something. Hope this helps.
May 13, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Loose vane/fin on the Maytag LDE8406ACE
On almost all dryers the top will release by itself without requiring you to remove the front. There are two small clamp-like mechanisms under the top on the front side. They can be released easily by sticking a flat-tip screwdriver straight into them and pushing in. Once you open the top you can spin the drum by hand and tighten the screws on the fins. Take not however that some fins are only placed in by plastic snaps, and if it is loose it probably means that it is broken and will require repairs.
Dec 12, 2009 | Dryers
Dryer fins coming loose
Unplug Unit.
Refer to pages 5-2 and 5-3 of the manual below to see how to expose the drum by lifting the top of the machine. Then turn drum very slowly and only until the screw holes for the missing fins are within your reach. Most of these dryers have two sizes of fins make sure you order the right one if you need to replace them.
Good Luck
Download this file : Maytag Dryer
Sep 07, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer fin on model MDE7400AYW fell off.
Take the door off. Do this by first loosening the screws on the hinge.
Then loosen the screws on the left (they hold on a plastic flange-type thing) that hold the front panel on. Once it's loosened, then the door hinge will have room to wiggle out.
Once the door is off, then the front panel will swing down--and you can lift it off the flanges that hold the bottom of the door.
Now you have access to the drum and can reinstall the fin.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Bulb failure pasrking light
Taillight bulb needs replacing, high above brake light at approx height of bottom of side widow.
Remove plastic panel at interior rear corner, remove thin backing insulation and reach up with fingers between metal flanges. Feel for a plastic "fin" approx 3" long x 1" wide that is attached to lightbulb. Similar "fin" for brake light is visible (white color). You need to feel above this. Fin is probably gray color, but you can't see it. Twist slightly counterclockwise and pull out. Bulb is attached to end of "fin". Insert new bulb and replace.
Nov 08, 2008 | 2002 Volvo V70
The "fin" inside came off
if i remember right ..remove washer top remove hose or pug in top of outer tub rotate basket until fin is at top i believe you can acess screw through hole..of course i have been known to remember wrong and apologize if i have this time let me know
Aug 19, 2008 | Kenmore Elite 45986 Front Load Washer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Maytag Atlantis MDG6400AW Gas Dryer Logo
235 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
