Question about Motorola Mobility H700 Wireless Headset
Thanks!!! Just wanted to say thanks. You fix saved my 2 Motorola H700's when I thought they were toast. Great work!!!
The number is 847625373 it always works for me
Posted on Sep 26, 2008
Conect to an other phone.What PIN# to use?Motorola H700
Use 0000 for the H700. If you are pairing with an Iphone, steps are as follows:
Headset is off, with mouthpiece closed
Open Iphone and select Bluetooth to ON
Hold down the center button (usually blue light) so it shows purple,
Open the mouthpiece.
The Iphone should merge.
Mine did not ask for a PIN, but if your does, it's 0000.
Thanks to the solutions above for guiding me thought this.
Feb 07, 2010 | Motorola Mobility H700 Wireless Headset
Changed phones want to install blue tooth h700 but it asks for a passkey. Where do I fibnd the passkey?
The passkey is 0000 (four zeros). If you need instructions do the following:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} First off, you want to have the H700 fully charged up and it's probably good to have the PHONE fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the PHONE.
On the PHONE, you want to push the "OK" button to get to your main tools area:
Choose Settings, then choose Connection:
Now you'll be able to pick which type of connection you want:
You want bluetooth, of course, so pick that:
Now you can specify that you want to add a new Handsfree device (even though, logically, you should go to Setup in my eyes):
Select Look For Devices, at which point the PHONE will scan for available units in the bluetooth frequency spectrum and hopefully find your H700 bluetooth headset. Assuming it does, it'll cheerily report the news:
If your PHONE doesn't find the headset, I suggest that you run the scan another time or two. Also make sure that the H700 is still showing purple, not blue or flashing blue. That should be all you need to do!
Once the PHONE has found the H700 unit, you need to actually pair them, so don't stop here. Select the H700 and you'll be asked if you want to bond the two units:
You want to say "YES", of course, at which point the PHONE will ask you for the bluetooth passkey of the H700, which, like all Motorola bluetooth headsets, is 0000. Enter it:
Choose "OK" to proceed to:
The phone has saved the pairing passkey, now it'll disconnect and search for it again in regular connection mode:
Hopefully it'll still find it, and verify the PIN:
Now, look at the H700. Notice it's no longer in the purple "pairing" mode but has switched to the regular slowly flashing blue mode. You're up, running. I hope this helps and Good luck!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Please remember to vote 459e9de.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | Motorola Mobility H700 Wireless Headset
H700 - microphone not working or am I on mute?
Ok here is the answer. There H700 have a small foam windscreen inside over the microphone that over time block the sound. The answer is to carefully open the unit and remove the obstruction and clean residue from the microphone and it will work like new. here is a link to pictures and instructions. http://www.geocities.com/jconkwright/H700fix.html
Jul 23, 2008 | Motorola Mobility H700 Wireless Headset
Is H700 compatible with the iPhone?
Here is a straightforward procedure to "pair" the Motorola H700 bluetooth headset with an iphone
1. Turn off the headset by folding the microphone.
2. On your iphone, go to settings-->General-->Bluetooth-->tap tp turn ON
3. To activate your headset, hold down the center button and keep it pressed while you fold out the microphone.
The iphone will immediately detect the device and state "not paiired"
Ignore this message and go ahead and tap on the headset menu displayed on th eipjone screen. You will e prompted fot a security code. Please enter 0000. The iphone will confirm that the devices have een paired successfully.
You arer done! To verify, try placing a call from the iphone and you will see a new menu on iphone asking you to choose the headset H700 or speaker phone.
Step 3 is the most important step in getting the two devices to talk.
Apr 23, 2008 | Motorola Mobility H700 Wireless Headset
Unable to pair with phone, needs the passcode for motorola H700
try The default settings Of 0000
Or 1-2-34.
Mike @ compurepair.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
No sound. Will not play ringtown anymore.
Sounds like your battery is dying and the unit is saving energy.
Mar 13, 2008 | Motorola Mobility H700 Wireless Headset
H700
go to www.n1wireless.com get another one of these for about 30 bucks.
if yours has water damge it probably toast water always seems to ruin electronics
Jan 14, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H700 wont stay connected
sounds like the battery in the headset is going bad you can get another heaset like this cheap at www.n1wireless.com.
Jan 03, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
22 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
