Question about Canon PowerShot G9 Digital Camera
Canon powershot 9
I have the powershot 9, I used to record movies and everything worked fine.
Now, when I record a movie, it is doing it at double speed. So when i play the movie, it is double speed.
how do change it back to be normal speed?
  • 2 more comments
  • Anonymous Oct 25, 2008
    Same here. Really fast video playback with no sound.
  • Anonymous Oct 28, 2008
    Oh man...I have the same problem...
  • jencomenz Nov 02, 2008
    Same problem - please help the movie is of my daughter's dance recital.
  • tandw Nov 08, 2008
    Exactly the same problem, the video function was working fine NOW double speed with no sound.. Harvey norman advised possibly 6 week wait to fix
  • 4 Answers
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for future recording.
Posted on Feb 04, 2009
Canon PowerShot SD1100 IS Digital Camera I used this camera to take movies. When I play it back on the camera and after downloading to my computer, it plays as if it's set for fast forward and there's no...
Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
Mar 11, 2017 | Canon PowerShot SD1100 IS Digital Camera
I am looking for how to shoot movies with this camera. In English, please tell me how..thanks
Press the power button.
Aim the camera at the subject.
Do not touch the microphone while recording.
Sounds such as from pressing buttons will be recorded in
the movie.
Press the movie button to shoot.the movie button is towards the right of the view lens.
Recording starts.
During recording, the elapsed
recording time and [ Rec.] will
display in the LCD monitor.
Press movie button again to stop recording.
Feb 05, 2011 | Canon PowerShot SX1 IS Digital Camera
Can i take movies with my canon powershot SD1100SI
Yes. Select the Movie mode (movie camera on tripod icon). Press the FUNC/SET button to select options, then press FUNC/SET again. Press the shutter release button to start recording, press the shutter button again to stop recording.
For full details, refer to the section "Movie Shooting" in the manual. If you don't have the manual, you can download one from the manufacturer's web site at http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd1100_is#BrochuresAndManuals
Jul 28, 2010 | Canon PowerShot SD1100 IS Digital Camera
How do you use the camera recorder on Canon powershot s31s camera? I would like to know how to record, save and then download short "movies" on the camera.
Just to the right of the viewfinder is a silver button with a red dot in the centre. This will start / stop recording. Set the camera dial to Auto, press the red dot button, and your recording will start. When ready, connect the camera to your computer with a USB cable and the movies will download at the end of the still pictures.
You might find recording suddenly stops after a while - this is because of a size limit for movie files. You can get over this by changing the resolution that the camera records at. It's quite complicated so I suggest checking the user manual or downloading it from the Canon webiste to choose what quality if resolution to use.
Nov 18, 2009 | Canon PowerShot S3 IS Digital Camera
How do i change the movie resolution canon a510
set the camera in movie mode.
press the function(f) button.
select up and down arrows to select your selection.
Mar 05, 2009 | Canon PowerShot A510 Digital Camera
Grainy movies
Go to menu and select images quality
There are three settings for quality, SuperFine, Fine, and Normal. Movies can be capture at 640x480 and 320x240 at 30 fps and 15 fps.
Jan 24, 2009 | Canon PowerShot A620 Digital Camera
Optical zoom problem in movie mode
Your camera is not broken. That's by design. Canon cameras do not allow optical zoom use while in movie mode. Canon claims that using the optical zoom in movie mode would cause excessive noise in the movie. However, you can use digital zoom in movie mode. You'll need to go into the menus (press the menu button) and turn digital zoom "on" if it's currently off.
Oct 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Can't change settings on movie option
To change movie resolution:
1. Set control dial to movie mode
2. Press the Func/Set button
3. Scroll down to the recording pixels icon (probably 320 on yours right now)
4. Use left/right arrow to select 640
5. Press Func/Set button
May 23, 2008 | Canon PowerShot G7 Digital Camera
Stuck in movie mode, but won't record
internal microswitch connector has been damaged.so it has been stuck at movie mode ,it can be replaced.
Mar 06, 2008 | Canon PowerShot SD600 Digital Camera
Downloading movies from PowerShot SD850 IS to Mac G5
Sounds like you are watching the thumbnails but the files are still on the camera... try downloading/transfering via iphoto.. the files should show up in your iphoto library and if you double click them, it will launch quicktime and allow you to play it...
let me know if that gets you there...
k
Jan 27, 2008 | Canon PowerShot SD850 IS Digital Camera
Canon PowerShot G9 Digital Camera Logo
429 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
