Moffat Washer -front Load Model MCCH611HWW. IS it possible to connect this washer to kitchen faucet with uni-couple hose? Thanks
  • 52 Answers
SOURCE: motor coupling
Pull the front cabinet off. The pump and motor need to be removed. The pump need not be completely removed, just push aside. Both the pump and motor are held on by simple snap clips.
The coupling must be carefully aligned when reinstalled. Be careful that the coupling pins line up when the motor is reinstalled.
Posted on Feb 24, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore 44072 Front Load Washer Drain Hose Cleaning
Try this link for step-by-step instructions. More than likely you will have to clean the drain pump as well.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are having trouble draining the water from the wash tub, and cannot get it to drain with a shop vac, you can drain it directly from the tub. If you don't own a shop vac, you may have to bail. If your drain pump does not have a clean out trap, remove the inlet and outlet hoses to access the inside of the drain pump. Inspect the pump impeller for obstructions and/or damage. If the water will not drain when you try to pull a vacuum on the drain line, you may have to disconnect the drain hose from the bottom of the wash tub. In some front loaders, there is a ball valve in the drain hose from the bottom of the wash tub to the drain pump. This ball can act as a collection pint from lint and debris. You will need to remove the hoses from the bottom of the wash tub to clean this area. I would recommend doing this as a LAST resort. Often, it can be difficult to reconnect this hose to the tub and get it to seal correctly. I hope this helps you. Please post back if you need further assistance.
Posted on May 28, 2008
  • 177 Answers
SOURCE: washer drain back flow to sink
No you do not want to restrict the machines pump out feature, FIX the house drain! call Roto Rooter if necessary.
Posted on Jul 12, 2008
  • 3230 Answers
SOURCE: whirlpool duet washer model: GHW9200LQ
I found this in when I looked it up.
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. - or -
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operati
Posted on Mar 28, 2009
SOURCE: MY MOFFAT WASHER SPIN SCYCLE WILL NOT WORK
moffat washing machine does not remove water after spin cycle
Posted on Aug 08, 2010
I have a Frigidaire front load washer model number Ftf2140es0 it will not fill with water. You can hear it click like its trying to fill but there's no water coming in
Here is checklist.
Start with the faucet that supplies the water to the machine.
It is flowing freely?
You will need to detach the washer hose to check that (and put a garden hose to the outside).
If the water is flowing freely from the faucet, then detach the hose to the washer and carefully inspect the filter screen inside the coupling on the back of the washer. The tiny (about 1/2 inch diameter) screen may be plugged up.
If the faucet, hose, and filter screen are good, the water flow solenoid could be defective.
That is the plastic piece where the 2 hoses attach from the outside. It has a wire connector as well.
God bless your efforts.
Oct 12, 2015 | Frigidaire Washing Machines
Washer does not fill
Widgett,
I understand that you are having trouble with water entering into your washer. Here are a couple of things to check out.
1) The water supply is possibly not adequate in the area where the washer is located. Check another faucet in the house. Wait until water supply and pressure increase.
2) The water supply faucets are not completely open. Fully open hot and cold faucets.
3) The water is being used elsewhere in the house. Water pressure must be at least 30 psi. Avoid running water elsewhere while washer is filling.
4) The water inlet hoses are kinked. Straighten hoses
If you are still having issues, I would suggest to contact a local authorized technician. When they come out they can take a look at the appliance up-close and determine what exactly is going on.
-Best Regards-
Jan 16, 2014 | Frigidaire GLTF2940ES Front Load Washer
Water wont run into washer
Hi oscar collins,
I understand that water is not entering into your washer. There are some things that can be possibly causing this. First i would check to make sure that there are no kinks in either the hot or cold water hoses leading into the washer. Next would be to check and make sure that the faucets running to the washer are fully open. Lastly I would make sure that the water pressure is good by checking another faucet in the house. If there is good pressure, the faucets are fully open, and there are no kinks I would contact the manufacturer for further assistance. Hope this has helped.
-Best Regards-
Jan 05, 2014 | Frigidaire ATF6000ES Front Load Washer
My machine is Kenmore Elite front load It is
Hello Sandra,
The FH error code means the computer on the control board didn't detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the screens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean, check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced.
Thanks for using FIXYA.com
GENE
Jan 10, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite quite pak 2, HE3 shows F then H and quits the cycle.
The FH error code mean that no water was detected entering the machine.The things to check are,a pinched or kinked water hose into the washer, the faucets off or if faucets on make sure that something has not restricted the water flow through the hoses..this will be possible espically if they washer is connected using "AQUA FLOW FLOOD STOP" ..the internal flood stopper will cause water flow to be cutoff for no reason. Also check the filter screens on the back of the washer where the fill hoses connect to,for debris in the screens.
If all above checks ok i would suspect the part called the FLOWMETER was defective in the washing machine.
GENE
Aug 28, 2011 | Kenmore 42822 Front Load Washer
Error code #E70
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened.Hope this helps... Please post back for more information.
Daniel
Nov 16, 2010 | Kenmore 43142 Front Load Washer
Samsung washer
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 28, 2009 | Samsung WF337AA Front Load Washer
What does efo mean
Electrolux Washer Fault Code for EFO or EF0
Drain Filter is Clogged. Resolution => Click lint filter for soap buildup or other debris. Check drain hose.
Oversudsing - A high efficiency detergent was not used.
Too much detergent was added. Resolution => Use only a high efficiency detergent. Follow manufacturer's recommendation for dosage. Amount may need to be adjusted for water temperature,
water hardness, load size and soil level.
Hot water doesn't enter washer - Hot water hose is connected to the wrong faucet. Hot water faucet is not turned on. Resolution => Connect hot water hose to hot water faucet and hot inlet on
washer. Be sure hot water faucet is fully opened. Check water heater.
Jan 03, 2009 | Crosley CW5000 Front Load Washer
Flashing H F at rinse cycle
be sure both faucets are turned full on ckd screens in washer end of hoses in valve ck for screens in faucet end be sure all are clean if problem persists suspect flowmeter if this model has one remove top panel on left side connected to dispenser hose ..small round objest with wires connected small turbine inside spins with water flow and triggers small leaf switch..switch is usually the problem not ther turbine
May 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine won't fill with water
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Sep 15, 2006 | Malber P21 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
