Question about Webroot Spy Sweeper (spysweeper) for PC
Webroot spy sweeper
  • It would not sweep. I reinstalled it and I was able to conduct a sweep. However when I tried to connect with the internet again, my computer froze. I had to uninstall Webroot in order to run my computer. I also have Trend anti-virus. Might there be a connection between these two?
  • tarryrose Sep 26, 2008
    for rickzilla:
    What was your solution? I could not get any further info. Your message stopped after "For what it's worth..."
    tarryrose
  • 706 Answers
I too have Trend PC Cillin ( anti-virus ) and Webroot Spy sweeper... I schedule sweeps at different times so there is no overlap or conflicts.. I am running windows XP Pro ( i do not like Vista... even thou I may not have any choice at some point) but I have not had any conflicts or lockups between them.. There may be some other underlying issue with your system... For what it's worth...
Posted on Sep 26, 2008
  • Rick Gelin
    Rick Gelin Sep 26, 2008
    Hi Tarryrose... I was merely pointing out to you that I have a similar set up to yours and did not have any problem with accessing the internet. My point being is that there should not be any incompatability issues with them on your system and that there may be some other underlying system based problem with your computer ( Memory limitation or other).. Instead of using Spy Sweeper.. try downloadiing Adaware SE for home use from Lavasoft.. it is free and see if that works on your system.. http://www.lavasoft.com/ if it works for you without problems then use that instead of spy sweeper.. any anti spyware program is better than none.. Let me know how you make out...
    Good Luck
    Rick
I was sweeping my computer and the sweep froze when nearly finished and I can't get it to turn off or do anything.
Try pressing Ctrl+Alt+Del, clicking task manager, then the processes tab and right click the one for Spy Sweeper and click end process. Then start the program again. If all else fails, try restarting your computer. If this happens every time you run the sweep, uninstall and reinstall the program.
Jan 01, 2011 | Webroot Spy Sweeper (spysweeper) for PC
Uninstalled old version of webroot spy sweeper and no internet
try another internet browser. if that won't work post a comment and i will see what else could be the problem
Jun 28, 2010 | Webroot Spy Sweeper (spysweeper) for PC
Don't sweep, 3of 3 shields are off
activate shields by pressing the correct buton(it should not be so hard to find it)then try again...if not then you need to reinstal your product...
Nov 14, 2009 | Webroot Spy Sweeper (spysweeper) for PC
I have weebroot cant sweep
There is a serious problem with spy sweeper webroot V 6.0. If that’s what you are using, uninstall it and use V 5.5 instead until they fix the problem.
I hope this helps
Jul 19, 2009 | Microsoft Windows Vista Home Basic Edition
Webroot won't sweep as per schedule
check your fire wall exceptions tab from control panel /add program(webroot spy sweeper)/check box next to this entry?
Feb 21, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Spy sweeper
In which place you click on the icon of sweep.
In the menu, on the screen or directly from the directory where you can find the sweep.
There are all kind of possibilities.
Problem with the registry.
File is moved
Version expired.
Probably the easiest way is to reinstall sweep.
Nov 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Spy Sweeper won't sweep after subscription renewal and upgrade to 5.5
Hello,i have been reading your problem....This is simply because you have too many anti-virus programs running all at once.... I reccomend you remove the other 2 anti-virus software....
thanks for your question,
have a nice day....
Sep 10, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Webroot spysweeper won't sweep
i had the same problem getting also an error message when i would log in about a valid definition file and go to program option page to update the definition file, after trying fixes from others i found one that said to reboot computer and put in safe mode, then open spy sweeper in safe mode, everything was in large print and nothing was turned on, so i rebooted the computer again and this time when the screen came up came up normally and not in safe mode and most of all there was no error message, my spy sweeper is now opened and now it is sweeping like it is suppose to do i don't know who was the person that posted the resolution but thanks it works so everyone try it.
Aug 01, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Mycomputer, when first turned on reads: "the connection to the spy sweep has been lost or terminated."
Related to this question -
http://www.fixya.com/support/t206134-webroot_spysweeper_sweep
It's your Webroot Spy Sweeper that's having problems - it may be related to your antivirus or firewall (try updating them), or if you're using Vista there's an incompatibility with the automatic update. Some of the possibilities can be found on Webroot's support site -
http://support.webroot.com/
Start with updating Spy Sweeper to the latest version (by manual update) and then branch out.
Jun 19, 2008 | Computers & Internet
I have seen this problem a couple times. The only fix that seems to work is uninstalling Spysweeper and then reinstall it again. If you go to start>Programs>webroot you will see an uninstaller. Run that, reboot the computer, then reinstall again from your install disc.
Jun 04, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Webroot Spy Sweeper (spysweeper) for PC Logo
100 people viewed this question
Top Webroot Computers & Internet Experts
Mike
Jerry
Jerry
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
