Question about Sewing Machines
Dropping Feed dogs on kenmore model 19233
Anyone know how to drop the feed dogs for free motion sewing? how can I drop the feed dogs on my kenmore sewing machine model 385.1278180??
  • Anonymous Mar 12, 2014
    Feed dog on Kenmore sewing machine 385 17626 will not raise after lowering to allow fabric to move
  • Nancy Hancock Oct 28, 2017
    I have the same problem on the 385.16221 Model. Help someone !
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
    That is the procedure, however the lever just moves and doesn't do anything
My machine has a "darn" setting that drops the feed dogs. Does yours?
Posted on Aug 16, 2009
2 Suggested Answers
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
Nov 27, 2016 | Kenmore Sewing Machines
Yesterday, while machine quilting, I heard a clank. Now the feed dogs won't feed the fabric. The feed dogs seem to move back when I start sewing; it seems as if they stayed forward before...
Did you check to make sure the feed dogs weren't inadvertently dropped. Most sewists drop the feed dogs for free motion quilting or darning.
Oct 10, 2016 | Singer 4210 Inspiration Sewing Machine
I have a jem 639 how do I cover the feed dogs
Probably best to consult your owner's manual. Either your machine has a lever or dial to drop & raise the feed dogs. If your machine does not have that capability, you would need a feed dog cover for your machine.
Nov 16, 2015 | Sewing Machines
How can i do free motikn quilting with my machine
On page 35 of your manual (see link below), there are instructions for darning. It looks like your machine needs to have the darning plate installed over the feed dogs before you can perform darning or free motion quilting. If you do not have the darning plate, then you will need to get one.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0CFAQFjAH&url=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2FB1dzfyluFLS.pdf&ei=jkMpVYmGFsWzoQTryICoCA&usg=AFQjCNEBTgKmXv2EyHiiw-px33CFogPHXA&bvm=bv.90491159,d.cGU
Mar 14, 2015 | Brother LS2125 SEWING MACHINE. D/B
Free motion, but can't find the cover fotr the feed dogd
Set the stitch length to 0, stitch selector to straight stitch. Find a thin piece of plastic or cardboard and punch a smooth hole in it for the needle to go through. Tape the plastic over the feed dogs with the hole aligned under the needle, and you should be good to go.
The fake credit cards that show up in junk mail are perfect for this.
Feb 04, 2014 | Consew 206RB
Can you drop the feed dogs on kenmore 385.1233280 or do you have to remove them to do free motion quilting?
Do you have your manual? Normally, there will be a lever next to your bobbin area to lower your feed dogs if you have a vertical bobbin. If, it is a horizontal bobbin it will usually have a cover to put over the feed dogs. If you are in doubt, take your machine and go to your local Sears sewing machine department, usually your salemen are very helpful and give great advice for free.
Jan 27, 2011 | Kenmore 19233 Computerized Sewing Machine
Can I do free motion sewing on a Kenmore Ultra Stitch 12? Model 158 1595281 serial #31011208
If you can lower or disengage the feed dogs you can stitch free motion.
If the the feed dogs cannot be adjusted as described, you can set the stitch length to zero.
You can also tape an index card over the feed dogs and punch a hole where the needle needs to enter the needle/face plate.
A darning or free motion foot is needed.
Take a presser foot with you when shopping for the foot as it is important to match the shank length.
Newer sewing machines are low shank and the older ones long shank.
You can also order online at Clotilde (see "which foot to use" for a guide).
Feb 18, 2010 | Sewing Machines
Drop feed
I found the drop dog feed lever. Problem solved.
Sep 28, 2008 | Sewing Machines
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
1,046 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
