Question about Tappan TGF320 Gas Kitchen Range
Oven and stop top problems.
My oven will not come on right away, It takes about 15 to 20min to come on. It will not come on if I am using the stove top.
My stove top I only have one eye working half way. the fire comes and on one side.
  • 116 Answers
The problem may one of two things - defective safety valve or defective ignitor for the oven.
The burners need to be cleaned up (the orifice ports) for the oven top
Posted on Sep 20, 2008
I have a kenmore 953 freestanding stove, my wife was making pizza and the oven made a strange sound, the display is no longer working, the oven stopped heating, and she attempted to turn on the burners,...
If you will type "SearsPartsDirect" into your search engine, you can then enter your model number and you will see all the parts of your stove.
What should have happened was, either an element failed, or the element wire connection inside the wall of the oven failed, or a wire has "toasted" in the electric box inside the back of the stove.
You will need to take the oven out (away from it wall, perhaps) & give it a good inspection with an electric meter to find out where the problem lies.
God bless your efforts.
Oct 02, 2017 | Kenmore 9535 Electric Range
Stove top works but oven doesn't
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
Apr 13, 2011 | Tappan 30IN ELEC IGNa Oven
Oven panel buttons will not turn on oven. Stove top works fine.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Feb 06, 2011 | Frigidaire Gallery GLEFM397DS Electric...
Need old West Bend Serving Oven -bun warmer- directions
I have one of those that I got as a wedding gift from my parents in 1975. They were popular then. My mother had always come out with nicely warmed buns, but when my wife and I tried to use ours, our buns were soggy--from too much water, I guess.You have to use it on top of the stove, not in the oven. Try putting in about a half-inch of water and put in the middle piece. If it floats, then you have too much water. Put the buns inside, place the lid on, and put it on low heat for 2-3 minutes. You can regulate how soft or crisp the bun would be by opening the steam vent for more crispy bread, or closing it for it to be more moist. You can experiment with it, but yes, you DO need to use it on TOP of the stove.~ Barry
Apr 23, 2010 | Toaster Ovens
Touch pad will not unlock after running self clean cycle,
ran the SCC and the oven door unlocked when completed but the touchpad did not. Can;t use over at all, top of stove works fine. None of the bottons for the oven works. still says self clean completed, will not go away, can't use oven at all.
Dec 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
I have electrical noise coming from the stove/oven
I'm assuming you're talking about a cooking stove/oven in the kitchen causing interference with your computer sound. If it is making enough of an arc to cause eletrical interference on your computer, it could be a bad short in the stove/oven and you should get someone to check it out as it could start a fire in your house. One thing you could check first is to make sure all the burners are turned off. You can pull the heating coils out of their plugins on the top of the stove for cleaning purposes. Take each burner out and check for burn marks on the contacts that plug into the sockets. Clean and re-insert the burners back into the sockets pushing them all the way in and then retry the stove to see if the problem still exists.
Nov 05, 2009 | Computers & Internet
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Tappan TGF320 Gas Kitchen Range Logo
123 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
