Question about Whirlpool GH6177XP Microwave Oven
Overheated microwave I thought I turned on the timer and I ran the microwave without anything in it The fan came on and then it shut down completely is it ruined.
This is exactly what happened to my microwave, to fix this i took out the microwave hot plate were you put the food onto and ran it under cold water, i then put it back into the microwave if you do not have a hot plate run a cloth under some water and wipe the microwave too cool it down, i then took out the plug and turned the switch off,i then left it for a while say 20 min came back put the pug back in and turned on the switch and left it for another 10min i came back and it was working again!!!
Posted on Mar 27, 2010
  • Whirlpool Master
  • 9,098 Answers
Hopefully the magnetron thermal cutout or thermostat protected the magnetron from destruction!
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 26, 2008
Hi I have a Sanyo Convection Microwave EM-C5779V and when the timer goes off the fan seems to continue to run and won't turn off when I hit the cancel button and have to turn it off at the wall.Help?
the fan may keep running to keep it from overheating until it cools down, if you let it go and it shuts down eventually should be no problem, maybe 3 to 5 minutes it should shut down. fan running is not dangerous however if it never stops then the fan will wear out
Jan 01, 2016 | Sanyo Microwave Ovens
I THOUGHT I SET THE TIMER-YET I HAD SET THE
Without food for the microwaves to be absorbed by, the magnetron (heating device) would have most likely overheated. There is a thermal overload switch (safety device) that acts like a fuse and turns everything off if overheating occurs like that. You would need someone that could take the microwave down, disassemble and check to see if the 'fuse' is bad or the magnetron is bad, they can both be checked with an ohmmeter. If you need to hire someone to do this, it may cost you more than the cost of a new unit if the magnetron is the item that has failed.
May 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave shuts off and will not re start until completely cooled down.
I would suspect that the magnetron is overheating and that the magnetron's thermostat is cutting power until it cools down.
It may be overheating because the internal cooling fan is not running when you're cooking.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will soon be destroyed.
It may also be that your filter is clogged, or your exhaust duct work is clogged.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please reply directly to me with your full number from the tag on the unit so I can help you with free do-it-yourself tips or an estimate.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Feb 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Frigidare FMV156DCG Overheated?
I have the same problem....I think its the door switch because if you lift up on the door handle while you've got the timer counting down, it should start the microwave hum....
Apr 26, 2009 | Electrolux Microwave Ovens
Microwave shuts down after cooking three or four minutes
Your magnetron is overheating and tripping the thermostat, which interrupts power until it cools.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Nov 20, 2008 | Maytag MMV1153A Microwave Oven
Samsung microwave
I have a Samsung model 1032BB in my R.V. Starts up all by itself and then I can't turn it off/on; have to unplug it. Should I have it repaired or should I replace it?
John
Sep 06, 2008 | Samsung SMH7178STD Microwave Oven
No sound
You mean it heats the food but the fan seems to not be running?
If so, that could result in overheating damage to the magnetrn very quickly!
Or do you mean that it doesn't beep anymore?
If so, that may mean that the beeper got turned off somehow.
To select the desired sound (if any) press Setup, then select either Simple Beep, Melody or No Sound and then press Start.
We have the entire owner's manual on our site at:
http://www.microwavedisplay.com/r1750_r1751_r1752_r1754_om.pdf
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 19, 2007 | Sharp R-1750 Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Whirlpool GH6177XP Microwave Oven Logo
1,895 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
