FixYa.com
Tags:
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
KF-50WE610 screen sizing problem
I purchased the KF-50WE610 a couple months ago at bestbuy, having my DVD hooked up to video 5 with component cables. Yesterday I went and got an HD cable box from Time Warner, it's a Pioneer connected into Video 6 with component cables. But i'm unable to change the aspect ratio and screen sizing in Video 6. I'm still able to cycle through the sizes in video 1-5, 7. Video 6 will only show "FULL" mode, but it will still cycle through Vivid, Standard, Pro picture settings. Even with the HD box turned off it still will not change from full.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 30, 2006
Not Rated (0)
agoraquest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Many cable boxes are never truly off. When you think you've turned it off, it's really just sending a blank signal. If your 'Video 6' label (or whatever you renamed it to) disappears after a few seconds, that means the TV is receiving a signal. Try unplug
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
agoraquest
Rating: 0%, 0 votes
Your HD cable receiver is configured to provide a 720p or 1080i output, regardless of the channel. You need to access the configuration menu and see if there are other options, such as 4:3 Override (a feature provided in the Motorola DCT5100 and above HD cable receivers). If such an option exists, select 480i. This option switches the output to 480i on non-HD channels, allowing you to use the WIDE MODE feature. You still will not be able to use the WIDE MODE when viewing HDTV channels.
Can you Help with these Multimedia Projector Replacement Lamps problems?
Sony XL-2100U Projector Lamp for KF-42WE610,...
Sony KF-60WE610
Sony KF-60WE610 TV remote is... Answer This...
picture in picture problem with...
I have the computer set up... Answer This...
Sorry did not know if I posted...
posted by ttaris on Feb 23,... Answer This...
I have read that OEM compatible...
I have read that OEM compatible... Answer This...
Won't come on unless cold and...
I have a Sony KF-42WE610 that... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
