Question about OKI C5100n Laser Printer
Wireless connections for 3500/4500
Does the printer need anything to make it wireless compatable? just out of box
  • OKI Master
  • 4,338 Answers
This printer has a 10/100 Base-T wired Internal Ethernet Print Server .
To make it wireless ,you would have to purchase a wireless print server, which will connect through the USB port.
To save the expense of purchasing a wireless print server,I would run a cable from the router to the printer and set an IP address, the you can set the printer up on as many computers as you would need.
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Posted on Oct 07, 2008
Dell 2155cn
You can make your printer WiFi compatible by connecting it to your wireless modem/router using the Ethernet port on the back of the printer, if the printer is located within a reasonable distance from the modem/router. The cost of an Ethernet cable (even a longer one) is probably less than the cost of the wireless adapter (I assume you have not bought the adapter yet).
To find out if the wireless adapter is compatible with your printer, you can call Dell technical support (for the printer or the adapter).
Hope this helps.
Jul 01, 2014 | Computers & Internet
Epson stylus sx215 wirless or not
The Epson Stylus SX215 is not a wireless printer so you will need a USB cable to connect to your printer and print.
If you want to be able to use the printer wirelessly you have a few options:
  1. Check your internet router (assuming it is wireless) to see if it will support and share your printer (Check for compatibility with your printer).
  2. Look for a replacement router that will share and support your printer (Again, do your research before you buy!)
  3. Consider replacing your printer. Most new models are wireless and very similar to the SX215. The down side is that cartridge volume is much smaller on many of the budget models like the XP205 or SX235W.
Hope that helps.
Jul 16, 2013 | Epson Stylus Multifunction Inkjet Printer/...
How to make a printer wireless
Plug into a wireless print server.If your printer has a USB port, you can plug in a wireless print server, a small box into which you can connect your printer. The advantage of investing in a print server is that you don't have to connect the printer to a PC, which means you can use your laptop and print anywhere in your home.
.tmnAdsenseContainer{margin-bottom:10px;} We found plenty of print servers in the $50 range on Newegg.com, although many of the models cost closer to $75 or $100). Before you buy, make sure the print server is compatible with your printer (the printer's written materials are less likely to specify compatibility with print servers).
During the setup, you will have to plug the printer into the printer server, and connect that to the router using an Ethernet cable. Meanwhile, you'll have to install software on your computer and configure the connection, as you would when setting up a router.
also try this link will help you
http://www.makeuseof.com/tag/printer-wireless/http://www.ehow.com/how_4530941_make-printer-wireless.html
http://www.labnol.org/gadgets/make-wired-printer-wireless/12639/
Dec 27, 2012 | Samsung Office Equipment & Supplies
IS LEXMARK WIFI COMPATIBLE
There are Lexmark printer models available in the market that are WiFi compatible. Please visit the Lexmark website for more information about Lexmark's wireless printers. You might find one that will suit your printing needs.
The Lexmark X7170 printer does not support wireless printing. It doesn't have a wireless network adapter to connect to your wireless network.
Nov 26, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hello, I recently purchased a new HP computer with Windows 7 & a HP Officejet Pro 8500A wireless printer. I have Verizon FIOS. After much time on line and via phone with HP they could only give me a...
you can fix compatibility problems by right clicking on the printer ( add printer section under control panel) properties tab , then compatibility tab the clicking in the tick box and highlighting the os in use
apply then ok
That makes the printer compatible to the computer
if you got a disc with the printer , use and let the wizard instal the printer
Apr 01, 2017 | Actiontec (GT701WG) Wireless Router
My Printer
Depends on the printer but there are plenty of attachments out there to make printers wireless. Especially if it is a HP printer (if it is go to hp.com and check out the printer accessories for your model). If it is not hp type the model of the printer in google and add the word wireless and you should see if there is anything that is compatable.
May 28, 2009 | Acer Aspire 5315 Notebook
Wireless
It is true the wireless upgrade printing kit will not be compatible with C1315 All-In-One Printer.
And also instead of going for a wireless upgrade printing kit you can buy a Wireless All-In-One printer for the same price and a new printer with a Year warranty as well, Check this link Bellow:
http://www.shopping.hp.com/product/printer/Photosmart/1/storefronts/Q8401A%2523ABA
Good Luck
Sep 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Wireless Printers
buying a wireless printer is a best choice this days, you can find many brands in the market these days..
no need for the cable of any sort it is done wirelessly
yes it will be compatible just share the printer o the network and it will be shared amongst all PC
Jul 29, 2008 | Toshiba Satellite P205-S6287 Notebook PC
NETWORKING
yes of course you need a wireless router for that. wireless router are for wireless network (desktop pc also needs WAN)
Feb 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Sharing HP PSC 1410V All-In-One
Yes, you can and it is pretty easy.
You should get the HP Wireless Printing Upgrade Kit
(Q6236A#A2L)
Price: $69.99
Here is there product description from HP.
Get everything you need to print wirelessly in this simple upgrade kit! It includes a printer receiver and PC receiver for a wired desktop or notebook PC, and it's easy to both install and use.
Works with most HP printers and All-in-Ones, plus all PCs, wired or wireless.
* Print from virtually anywhere in your home or office via the wireless 802.11g connectivity
* Eliminate ugly cable clutter but still get the same print speeds as via USB
* Retain full all-in-one wireless functionality: print, fax from your PC, scan, and access photo memory cards access and PC status
* Set up fast: just plug the receivers into your printer and PC; there's no configuration
* Protect your signal from interception with the secure wireless connection
* Use with a network, or just one PC
* Compatibility: most HP printers, all PCs (wired or wireless)
** I checked and your HP is on the compatibility list - it is ok***
What's in the box?
1 printer receiver
1 PC receiver
William
Feb 15, 2008 | HP PSC 1410v All-in-One Printer
OKI C5100n Laser Printer Logo
77 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
