Question about Whirlpool Refrigerators
The freezer is working but the fridge isn't cooling. Numbers in fridge door are: WRN38RWG6 DA68-11043J
  • sarahcox36 Sep 26, 2008
    Thanks for your help - the fridge is now working.
    I believe it was the frost free function not working - we completely defrosted the freezer and a very long time later, the water started to drip through the vents!
    Thanks again
  • 750 Answers
Hi sarahcox36,
welcome aboard!
You say: The freezer is working but the fridge isn't cooling.
first think you have to look at is if the freezer is packed full or the frozen food is covering the air vents in the rear of the freezer not allowing the cold air to circulate back to the fridge!
They share the cold air and must have that circulation for the two to work properly.
Please check this.
Under your fridge is the small black tubes that run bck and forth next to each other.
they have the freon running through them that circulates to and from the compressor!
They may be covered with dust from years of not being cleaned! Which will keep the heat in and cause the fridge to stay warm !
I've seen where they were caked with 2-3 inches of dust and not visible! After 12 hours it was better and 24 hours great!
They should be gently cleaned every couple of months with a refrigerator brush that you can buy for 5 dollars at a hardware store .
Let me know that one of these two are the problem and get back to me!
How old is the fridge?.... READ Repair or replace?BELOW!!!!!!!!!!!!!!!!!!!!!!!!!
Bless You
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 20, 2008
Whirlpool Wrn38rwg6 Freezer isn't freezing and I
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Sep 16, 2011 | Whirlpool Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
I have a fridge freezer model number wrn38rwg6 . The problem is the refrigerator is not cooling down , the compressor is working could it be the thermostat . what do you suggest i do about this .
If the compressor is running it wont be the thermostat, it could be that the system is short of refrigerant you will need to get an engineer to check the refrigerant pressure with their gauges.
Nov 02, 2010 | Whirlpool Refrigerators
Whirlpool Wrn38rwg6 frige has decided to not cool properly
My first thought is it defrosting? Look into rear of the freezer and see if ice is building up on rear wall of freezer. If yes manually defrost and let me know what you find. If no I would want you to feel compressor for overheating or look and see if a fan has stopped working while compressor is running. Sea Breeze
Feb 20, 2010 | Refrigerators
Whirlpool REfrigerator Freez WRN38RWG6 How do you stop water
Turn Fridge off,leave open for 24 hrs,then shut doors and start.The defrosted water had frozen up high and the fridge then leaks
Mar 01, 2009 | Refrigerators
Whirlpool WRN38RWG6 fridge freezer. Fridge won't cool
...try taking the fridge to Thredbo or some other location that gets subzero temperatures and then leaving the door open 'til the interior cools down. Canberra this time of year could work. You could also try just filling it with some frozen water. Most service stations have it in plentiful supply. Best solution for a non-hottness deficiency.
Dec 07, 2008 | Whirlpool Refrigerators
Refrigerators Logo
264 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
