Question about Acer TravelMate 2300 Notebook
Vertical Lines in Monitor
I am having the same problems with the vertical lines. I currently have about 6 lines on my screen. They are always visible no matter where I go or what I do. I have a blue vertical line going across the monitor of my Acer Travelmate 2300. The machine is 3 years old, so I guess the hardware is deteriorating. I don't know if there is any cheap way to fix this. It is certainly a hardware problem - the line appears as soon as I start the computer.
  • 78 Answers
This is usually a screen problem and cannot be fixed however to verify if this is from the screen or from the video card you can connect a normal monitor to the back output connector of your laptop and check the display on the external screen.
This will tell you if it is the video card on the board or the actual screen. In either case it would be a hardware issue.
Posted on Feb 28, 2009
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
I have vertical colorful lines on the screen just got a new computer with windows vista
the monitor is bad if your getting vertical lines on it. Anytime you get vertical lines on any monitor, LCD, laptop LCD, etc, then that means the screen is bad.
Your monitor needs to be replaced.
Aug 09, 2009 | Envision Computers & Internet
Vertical lines on screen , is there a processor driver download to fix this problem
Vertical lines on a screen is not a processor problem, vertical lines is going to be a problem with the monitor or the video card. Try a different known working monitor on your computer and if the lines go away then you know that the original monitor is bad.
If the lines don't go away then try replacing the video card. If you have integrated video then the motherboard would need to be replaced. A processor driver download is not going to fix a vertical line problem.
Aug 08, 2009 | Dell Computers & Internet
If the lines are only on your laptop screen, it is generally the display IC on the LCD panel.
When plugged into an external monitor and you still see the lines, it is the video memory on your laptop.
Dec 23, 2008 | HP Pavilion dv8000t Notebook
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
Try changing the refresh rate.
Jun 02, 2008 | Computers & Internet
Definitely ask HP support. They should be familiar with this wierd problem.
Apr 13, 2008 | HP Pavillion ZV6000 Notebook
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
I am using an Acer and my screen has over 25 lines now. Same vertical lines. Can anyone tell me what I can do to correct it??
Rasheed
Oct 07, 2006 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
339 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
