Dryer has the choice of more dry or less dry for the settings and did great till now. One time setting and the clothes would be dry. Now it takes 2 or 3 times to get same results. Can I have some help with this problem?
-   we have to restart our dryer about 3 times to get the clothes dry.they are heating up but not drying.i have already disconnected the exhaust tube and checked for clogs but it was clear.i have opened the door and pushed the switch on the front ,like the dryer was closed ,and started the dryer and i feel hot air coming out but not much.is there some kind of blower that may have went out?-   bhicks75
The dryer is clogged disconnect the exhaust hose(usually a 3-4 inch thin spring like tube) from the back of the dryer and clean out the entire thing disconnect it from the window (I imagine this is what you have it connected through?) and make sure all lint is removed and then reattach. Also make sure you don't have to much slack going from the machine to the window. Cut any access hose off. It should go the shortest possible path no big loops or sags! After this it should heat up like you just pulled it out of the box.
my kenmore model 96575100 is not turning on at all -worked yesterday any hints - could it be the...
(More)
my kenmore model 96575100 is not turning on at all -worked yesterday any hints - could it be the button that turns it on is not connecting?
Have Roper EL5030V and the dryer doesn't seem to dry cloths in a reasonable amount of time. Please...
(More)
Have Roper EL5030V and the dryer doesn't seem to dry cloths in a reasonable amount of time. Please help.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
