Question about Olympus WS-200S
Erasing Hi, I have emptied all my folders, but it it's still full up. Any way of erasing stuff I can't see, because I used it also as a memory stick.
  • lucy4616 Nov 02, 2008
    I have the same problem. The device shows that all the files are empty, but that all the space is used up. I tried copying the folders to my desktop and now can't put them back because the device says there's no room. Ack!
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Posted on Feb 28, 2009
    Brigadier General:
  • 5,158 Answers
If you don't care about what is on the memory stick... just format it making sure you use the original file system. likely fat or fat 16.
Robert
Posted on Sep 20, 2008
What if I erased the...DMCI folder in my memory card? I can no limport my pictures in my desktop because there is nothing in my memory card..
It is not recommended to erase the DCIM Folder in the Camera as this is the root directory in the Digital Camera which contains DCIM (Digital Camera images). This DCIM Folder contains the sub directory where the images are getting saved. if the folder is deleted manually from the Computer, then the Camera will not recognize the Memory Stick inserted and the Computer also. if the folder is deleted or edited, then I suggest you to Format the Memory Stick again in the Camera using the Format option in the Menu of the Camera.
Thanks for using Fixya.
Jan 27, 2011 | Cameras
Tip
How to Delete Protected Folders from a Memory Sticks
<p>Folder on the removable media used both FAT32 and NTFS file systems in Windows operating system. Some of these attributes in the rule of the people (name, size, creation date, and time) can be seen, others have explicit measures to ensure Windows. Among the latter are "read only" (if set, the folder cannot be erased) and "hidden" (if set, the folder does not appear in the parent directory.) A folder is set with one of these protected attributes clear. With a few extra steps, but you can secure a folder from a memory stick.<br /> <p> <br /> <p>1. Connect the memory stick for your computer. Windows will recognize it automatically and make your content accessible.<br /> <p><br /> <p>2. Click the "Start" and "run" (without quotation marks) into the search box. Click the "Run" link, type "cmd" and press Enter. A command window opens.<br /> <p><br /> <p>3. Type the following commands in the command window:<br /> <p> <br /> <p>E:<br /> <p>cd "\ myfiles \ projects"<br /> <p>Replace "E:"with the drive letter for the Memory Stick and replace "\ myfiles \ projects" with the full path to the folder containing the folder you want to delete protected. Press Enter after typing each line.<br /> <p>4. Type the following command to remove the attributes currently prevents you from deleting the folder:<br /> <p>attrib -r -h folderName /e<br /> <p>"Folder Name" Substitute the name of the folder you want to delete. Press "Enter ".<br /> <p><br /> <p>5. Delete the folder by clicking "Start", then "Computer". Navigate to the folder you want to delete, click once and press Shift-Delete. "Windows will erase a protected folder from memory stick.<br />
on Jun 21, 2011 | Computers & Internet
My memory show empty inside it but at the properties shows my memory is full.how do i want to make the file visible without formating my memory?
Go to My computer, and right click on the icon for the memory stick.
From there you should have an option to format the memory stick.
You can do a quick format and this will erase all files including the hidden ones that might be the onces taking up space on your memory stick.
Nov 23, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
How do I empty the Lexar memory stick to create more room?
if you have moved everything off it, just right click and choose format.
You can do this from my computer, or disc managment (right click my computer/manage/disc managment)
Jul 10, 2010 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Feb 05, 2010 | Olympus WS-321M Digital Voice Recorder
Sony ICD-UX70/UX80 digital recorder...memory full problem
I solved the problem by connecting my Sony IC Recorder to the USB port on my McBook Pro computer and then emptying the trash can on the Mac computer. Visually (flashing red indicator light) and audibly (the recorder's sound that indicates something being erased), it was clear that mp3 files were finally, really being erased on the Sony recorder even though the recorder's own screen display had previously shown only empty folders and no files. Dragging files to the trash can doesn't really erase them unless you also empty the trash. All dragging to the trash can does is somehow mark the files in a way that, unfortunately, makes them invisible to Sony's file detection system.
Chuck in Omaha
Apr 21, 2009 | Sony ICD-UX80 Handheld Digital...
Fone memory full
hi my name is jasminder
hi have also nokia 6110 navigator
you need a file explorer for this delete the extra stuff using this software
thanks don't for get to rate
Jan 26, 2009 | Nokia 6110 Cellular Phone
PROBLEM: k750i Memory Stick Duo Pro - Sony
hi
first format the memory card and upgrad the firmwer of your mobile then check for the same problem, happen again change
thet memory card.
vyas
Apr 17, 2008 | Sony Ericsson K750i Cellular Phone
Panasonic Memory card is full
You might be looking in a different (empty) folder on your memory card. Put the card into your computer media reader and see what's on it. Otherwise just format the card from your camera and that will erase the entire card no matter what's on it.
Sep 20, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Memory Card Problem
Have you (or can you) formated the memory sticks when they're in the camera?
Sep 13, 2005 | Sony Cyber-Shot DSC-P5 Digital Camera
Olympus WS-200S Logo
155 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
