Question about Panasonic TX-32LXD1 32 in. LCD Television
Panasonic Viera TX-32LXD60
Hi, my tv seems to be stuck on standby. The screen won't come on when I use the remote as it usually would, and when I use the box- it comes on for about 2 seconds, clicks a few times then turns itself off. Oh and when its on standby, the red dot flashes every 3 seconds. Any ideas?
  • Anonymous Dec 21, 2008
    Just begun experiencing identical symptoms. The flashing LED, I suspect (guessing here), indicates the type of fault. The problem is only resolved after the TV is turned of for some 5mins, which, if there is an over-heat protection circuit, may be due to temperature. Our TV is either always on or in standby (never unplugged/off), so as overheating is the only issue I can immediately address to some degree, I have unplugged it, removed the rear cover and vacuumed out any/all dust. Was hoping to find a blocked fan, but could not see any fan(s), just heat-sinks. I will now unplug the TV at the end of the day to see if this reduces/removes the symptoms and will approach the seller in the New Year regarding return/repair. Will also revisit this forum to let you know what the outcome is. If in the meantime you have found a solution to the problem elsewhere please post it here.
SOURCE: Panasonic Viera TX-32LXD60 on screen display
On your TV remote, to the right of the "0" is an "i" - press it!
Posted on Jun 16, 2008
SOURCE: Panasonic viera problem
I have the same problem. Panasonic troubleshooting says to unplug it and replug in a different outlet. I tried but it did not work.
But this advice may be the best.  http://stafford.typepad.com/the_next_america/2004/02/panasonic_plasm.html
It is saying that the TV may be protecting itself if there is an ungrounded plug. Test your plugs before you go on. Best thing is to get one of the simple three prong plugs with the lights on it that tells you the state of your electrical circuit
Posted on Nov 25, 2008
  • 718 Answers
SOURCE: cant get the stand off a panasonic 32 inch TX
TX 32LXd60
Lay the tv face down on a flat surface. Do not scratch the screen ! Use a cloth.
Remove the 4 screws above the stand. Pull stand out. Replace screws.
You can get Operating Instructions from;
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
enter the model number- click search- and download the Operating Instructions . The Operating Instructions will illustrate the stand.
Posted on Apr 12, 2009
  • 583 Answers
SOURCE: Panasonic 50" Viera plasma on/off problems
its the problem in main board.any of the capacitors or ic are getting overheated that needs to be checked and replaced. thanks.
Posted on Jul 13, 2009
  • 8457 Answers
SOURCE: Panasonic TX-32LXD60 won't switch on. Red standby
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Posted on Feb 27, 2010
Testimonial: "Thanks for your help-at least I know what I should need to pay for to get it repaired now."
The tv i own: Panasonic TX-32LX77 LCD Monitor (TX32LX77) . i want to know if this is HD. if i hook up the tatasky HD box, will i get a full HD output? thnx
The TX-32LX77 is an HD TV but only has 720p (1366 x 768) resolution. Full HD is 1080p. (SD is 480i.)
I wish that I had better news.
(It's possible that you won't notice the resolution difference; small screens don't always need the full 1080 lines of pixels from top to bottom of the screen to give a crisp picture.)
May 23, 2011 | Panasonic Viera TX-32LX77 LCD TV
Need to find user guide and owners manual
Hello;
I have lost the user manual to a Panasonic TX-32LXD700 32" TV. Does any one know of a link to download a copy?
Many thanks to any one who can help?
Feb 10, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Hi I have a Panasonic VIERA TX-32LZD80 32 in. LCD TV TV which will not turn on. The standby light will flash continuously, but will stay on red if I press on the on button using the remote. My TV is...
BECAUSE THE QUESTION WAS ASKED BACK IN December 8, 2010, it is more likely that he has moved on. Anytime you have a product UNDER WARRANTY, USE IT OR LOSE IT. THINGS HAPPEN. DEVICES FAIL.
Dec 08, 2010 | Panasonic VIERA TX-32LZD80 32 in. LCD TV...
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Cant get the stand off a panasonic 32 inch TX 32LXD60 to put on the wall
TX 32LXd60
Apr 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Aug 18, 2008 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
May 22, 2008 | Televison & Video
Panasonic TX-32LXD1 32 in. LCD Television Logo
252 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
