Question about Panasonic KX-T7630 Corded Phone
Panasonic system KX-TD 816 chnaging to ADSL line.
We had this system working fine on PSTN line but in the process of changing over to ADSL will this work or do I need additional adsl CO module, if so which one.
  • bmehon Sep 21, 2008
    ADSL microfilters connected to the line jack have two out lets PSTN and RJ-11 (UK) hence cannot be reversed. I only have one ADSL line and second is standard STD line.
  • bmehon Sep 22, 2008
    System was bought in States a few years ago but an additional 8 station expansion card was added to the system a year later hence it is same on the cabinet side. I am planning to change over next week provided the ISP sort out the DSL line so I can upgrade the computer network first. I have a BT minimaster system working as back at present. Future Plans to upgrade 816 to VOIP system. I will let you know the out come after next week thanks for your input.
  • Panasonic Master
  • 2,460 Answers
No, it's the same. You install a low-pass filter that is supplied in the kit between the outlet and the CO trunk on phone system. If you don't you may hear a high pitched whine on the line from the DSL carrier.
The jack in the phone system is an RJ-14, so if you have more than one line, remember that the second pair may not be passed through the filter. Also read the face of the filter to see which is line and which is phone side. It's easy to reverse them.
Carl
Posted on Sep 20, 2008
  • Carl Navarro
    Carl Navarro Sep 21, 2008
    So does the eu version 816 have 2 RJ-14 jacks for lines and 8 jacks for extensions on the base cabinet, or are all the CO lines on cards? Here, the base cabinet cards are inside as 4 loop CO cards and the 8 stations. expansion is only via 4 co and 8 ext cards on the face of the cabinet.
Does a panasonic kx t 7731 have built in voicemail and if so how do i program it
You need to get a voicemail system. The 7731 is just a phone, but it can be used to access Panasonic VM or Built In Voicemail in a TA-824 system. The external product is a model TVA-50 and it comes with documentation on how to interface it to your phone system. If you have an old KXT-308 or 616, or any other older Panasonic system prior to a TD-816/1232, you're going to have a problem.
Carl
Carl
Dec 06, 2012 | Panasonic KX-T7731 Corded Phone
The coord connecting to the phone jack will not turn on the phone, is there an actual ac plug for this phone?
Since a 7456 is a phone for the Panasonic KXTD digital phone system, what are you plugging it into? It requires at the least, a TD-308/816/1232 KSU in front of it.
Aug 15, 2012 | Panasonic KX-T7456 Corded Phone
MY EXTENSION DOESN'T RING FOR EXTERNAL CALLS ON THE KX-T7433 SYSTEM WE HAVE INSTALLED. HOW CAN I GET IT TO RING FOR INCOMING EXTERNAL CALLS?
JUST AS YOU'RE TOO LAZY TO USE THE SHIFT KEY AND LOSE THE CAPS LOCK KEY, I'M TOO LAZY TO LOOK UP THELINK TO A MANUAL. HOWEVER, I CAN TELL YOU THAT YOU COULD GO TO THE PROGRAMMING MANUAL FOR A PANASONIC KX-TD 816/1232 AND LOOK AT DIL 1:N PROGRAM 603 AND 604. IT'S WHERE YOU SET THE EXTENSIONS THAT RING WHEN A CALL COMES IN.
Carl
Jun 23, 2011 | Panasonic KX-T7433B Corded Phone
Hey if we just purchased the kx t7453 phones from a neighboring business and we had nortel networks what is the main unit i need to run my line back to and how do i go about getting it
The 7453 is a Panasonic digital phone and it works on a TD series box. TD 308/816/1232 systems show up on Ebay for $100-600.
Some of the old digital phones will also work on the TDx series systems, but they take 4x the power of the 76xx/DT series phones.
With refurbished T7324's selling for under $100, it seems like you'd be better off using those.
Carl
Feb 12, 2011 | Panasonic KX-T7630 Corded Phone
I currently use a Panasonic KX-T7431 at work and I wnat to either know does it have an answer machine function within the phone or can I buy one to add to it , we cusstenly do not have any faciity for...
Generally, a 7431 phone plugs into a Panasonic KX-TD phone system cabinet. The 1232 starts as an 8 line 16 phone cabinet, the 816 a 4x8, and the 308 a 3x8. To those systems, you can add a TVx Panasonic brand voice mail system, or even a plain old ansering machine. Both would need to be probrammed by someone familiar with ringing and intercept groups in system programming.
A quick call to your Panasonic installer or dealer would be the best, as it's beyond the scope of this forum to provide instructions.
Carl
Aug 17, 2010 | Panasonic KX-T7431 Corded Phone
Manual for KX-T7230 User Manual
It's not exactly that easy. Here's a manual for the 816/1232 TD series phones. If you have a TD-308, it has a different manual.
Start on page 91 http://www.public.carl.airpost.net/Pana/TD/td1232user.pdf
Carl
Aug 05, 2010 | Panasonic Phone KX-T7230W
Panasonic kx-t7433 phone does not power up
The phone uses the outside pairs of a 4-conductor base cord to make the digital phone work. Check to see that you are using at least a 4 conductor base cord. Try moving it to another jack that works. If it powers up there, you probably have a mis-wired jack. You can also test it by plugging it into the cabinet directly if you have a TD-816.
Carl
Oct 23, 2009 | Panasonic KX-T7453 Corded Phone
Call Out line is lost
If you truly have a TD-816/1232 system consistent with the 74xx series phones, and not the 7130 you posted under, you need to find out what line you lost, or how another phone is programmed.
Go to a working phone, press PROGRAM 99 and the buttons on the key strip. They should say CO-001, 002, 003 etc. Now go to the non-working phone and do the same thing. A C.O. is programmed by the code 0 + the 2 or 3 digit trunk number, so you press the missing line button and dial 0-(0)01 STORE or 0-(0)04 STORE, depending on which end you lost it from.
Pick up the handset and hang it back up to exit programming.
Carl
Feb 13, 2009 | Panasonic KX-T7130 Corded Phone
Caller Id not working KX-TG6323PK
Don't mind. Returned the product to the seller. Thanks.
Jan 11, 2009 | Panasonic KX-TG6323 1.9 GHz Trio 1-Line...
Voice mesage
What manual did you download, where is the message located, and what is it recorded on?
A 7433 phone is just a phone, it has no messages. It is connected to a TD-816/1232 Key Service Unit and a TVS/TVM/TVA voice mail system if it's Panasonic branded.
When you call in to the TD system, the voice mail answers the call and plays the Auto Attendant greeting. Is this the one you want to change? Or do you want to change the greeting that you get after the AA answers any they dial your extension?
Each of those messages can be changed from the Message manager's box or from your own mailbox, using the codes and passwords supplied at installation.
Carl
Aug 27, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
125 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
