Hi there. i wonder if you could help. my son has an advent 3411 desktop pc and the display is gone. i tried 2 different moniters but there is no signal on both of them. i thought it must be the graphics card so i bought one on ebay. i fitted it today but there is no difference. the lights on the tower are alight and you can hear the fan whirring but there is still no display. have you any ideas?
  • james6string Sep 24, 2008
    thanks very much. i tried it and it works with a different cable.
  • 706 Answers
You may have a bad video cable.. borrow or buy one and try that..
Posted on Sep 24, 2008
My advent pc keeps showing no signal when trying to load windows xp home replaced graphics card and psu
HI,
Ones you install graphics card then the display connection with motherboard will not work.
1. Remove the display connection for your monitor from motherboard.
2. And connect it in Graphics card display port.
Hope it will help you.
Thanks for using FixYa.
May 20, 2011 | Computers & Internet
Turn on my computer, I can hear the fans, no beep noise upon starting. Screen says no signal found. I tried other monitor cables and monitor. No dice.
one of 2 things is happening a) if you have changed the cord and tried other moniters then the display port beit vga or dvi on you computer is broken you will either if you have agraphics card already installed then replace that but if you have no dedicated grapichs card you need to replace the mother bord
B) check your moniter to see if there is a source button if there is then push it to see if the image comes up repeat up to 3 times
ps: if you have a dedicated graphics card look at the back of you computer and if there are 2 different display ports be it dvi or vga (google image the terms "vga port" and "dvi port" to see what they look like) then plug it into the other on to see if the graphics card is broken
May 02, 2011 | Sony VAIO PCV-RZ56G PC Desktop
My hp moniter stopped working like a fuse blew. i was wondering if it has an internal fuse and how to get to it. It's an HP vs19b moniter. thanks for any help
Thank you for choosing FixYa. I recommend try going to any computer local center and have them check your monitor because there could be other parts have been affected by that problem, there could be other hardware that cause the problem why the fuse failed.
Hope it helps.
AnEspera
Apr 22, 2011 | HP Computers & Internet
I have sony vaio desktop. My moniter keeps going off and on. Tried different moniter does the same thing. Could it be something that the desktop might be causing. Also, last year I replaced my power...
When you say 'on and off' you have not indicated if the whole power on the monitor is going on and off or if the monitor remains turned on but the screen display goes on and off.
Is the monitor power plugged through the socket on the pc or direct to a power outlet?
multiplug power outlet boards are often a source of power failure.
Did you try a different power lead for the monitor and b) a different wall socket?
If it is the screen display that is intermittent you should check the graphics card is fully seated (if it's a separate one)
Aug 12, 2010 | Sony VAIO VGC-RB42G PC Desktop
Picture is too big on computer moniter
try to change the Display settings with a higher resolution, example 1024 x 768. It's under control panel - Display and Settings Tab.
Apr 01, 2009 | Dell 2350-DHB7R21 PC Desktop
No signal on advent monitor
Hi
First thing, change the cable and use a digital cable, Power everything off, disconnect the power from the moniter and the pc, leave it for 2-5min and then connect them back again.
Let me know what happens
Mar 23, 2009 | Advent 4211c Notebook
ONLY STREAKS OF COLORS when TURNING ON!
the problem is the update you downloaded someone mixed with your graphic chip.. causeing it to only display dots and lines. the hp logo with the back round is the start up page. here are 2 ideas you might wanna try.
1. if your graphics car is in a AGP or PCI, pull it out and try useing the default card build in the computer.. if it is the default go out and bye a cheap graphics card and see if that works.. if not return it and get your money back.
2. try useing a diffrent moniter.. your moniter might of blown out. if that still dont fix it you might need to contact HP or the moniters manufactuer.
hope this helped!
Oct 08, 2008 | HP Pavilion a420n PC Desktop
How to repair the screen of Advent 7092 Window XP version. Help Please!
This may not be damage, it could be the wrong driver.
Go to the control panel, look at the device menu to see if the display is possibly marked as not working correctly.
Then look at the display settings to see if new driver alternatives have appeared.
Incorrect drivers can damage a display; I've seen it happen (unfortunately).
Mar 27, 2008 | Computers & Internet
Moniter is black
hi sounds like you need to replace the lcd backlight which lights up your cd display when it goes you can still see things but it's very dim if you need help ordering that part let me know and i'll find you the product code hope this helps
Aug 08, 2007 | Balance CN6555 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
