Question about ViewSonic VX1945WM LCD Monitor
Drivers cannot be loaded...windows does not recognize monitor
Hi, After a computer crash..I have not been able to reinstall my monitor. The drivers do not load from the Viewsonic CD..manual option does not work either. On the device manager I have Yellow ? against "PCI device" and "Video controller (VGA Compatible)". I have downloaded the signed and unsigned drivers from the Viewsonic website for this monitor....no luck!!
The monitor does not show up on the Hardware manager, and windows has just loaded some pathetic generic monitor drivers. So theres no multimedia.
Kindly help.
Warm regards,
Pat Tobin
patricktobin@yahoo.com
  • patricktobin Sep 27, 2008
    Hi, Mediarich...you were absolutely right. The drivers did the trick. Warm regards, Patrick
    Scholar:
  • 188 Answers
I think after your crash you are missing the drivers for your graphics card and not the display. Check what kind of graphics device you have and see if you can find the drivers for that.
Posted on Sep 20, 2008
Hp vista and monitor hp2509 was working fine. i uninstalled monitor driver but now computer starts fine but monitor goes blank
Monitor drivers are built into windows OS, you can't uninstall the driver unless you went to devise MGR, monitor, and opened proprieties and hit uninstall, and even then when you restart windows, it will auto reinstall the hardware. So what you're saying does not make sense.
If you reboot and noting, try a system restore, if you have a windows disk, then run repair. But like I said, you don't install monitor drivers, DVD rom drivers, these are generic drivers that are made into windows. If you think a monitor has a driver that needs installing, explain how people install windows if they couldn't see the monitor.
Only onboard video and graph cards need drivers to run the video at its intended resolution, but it does not need a driver for the monitor, it's built into windows.
Mar 29, 2013 | HP 2509M 25 Widescreen LCD Monitor -...
I had a btand new 2011 quickbooks running on my computer then after a week it crashed. I can't open it and it gives me many error messages when I try to reinstall it. I have a 64-bit computer that has...
Hi there !
For some reasons computer can crashed because some corrupted, missing files, virus program or faulty driver installed. Faulty installed drivers or multiple drivers installed with the same drivers can crashed your computer. Running on Safe mode will remove mulltiple same drivers in your computer and it will run on fresh install driver when loading to normal mode.
I suggest to run your computer on safe mode.
To run on safe mode, just restart your computer and press F8 to run on safe mode. After going to windows setting, restart your computer again. Check if this solve your problem.
I hope it helps you and thank you for using FixYa!
Jan 09, 2011 | Computers & Internet
Where can I find drivers for Samsung's 910t monitor? A generic is controlling it now & it's not coming close to the quality it had. (The computer crashed & I installed a new hard drive but the...
The problem is not the LCD monitor; the problem is that the current device-driver for your computer's video-card is a "generic" ("low-resolution") device-driver.
Open "Device Manager".
Expand the "Display Adapter" section.
Double-click the video-card.
Click "update driver" and let Windows access the Internet, to search for a better driver.
Oct 22, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
New HP desktop goes through Post and starts Win 7 splash screen, then the monitor drops off.
1. Restart the Computer
2. Press F5 or F10 a few seconds after POST (and before Windows tries to load) to access SAFE MODE
3. In SafeMode head straight to Control Panel - System - Device Manager
4. Remove all drivers under Display Adapters
4b. Remove all drivers under Monitors
5. Restart the computer
If u are able to get into windows using generic video drivers, then the problem is resolved. It's time now to reinstall the video drivers for u video card.
Mar 15, 2010 | Princeton Digital VL173 Monitor
Recently crashed. reloaded with original recovery
After you restore your computer, you must also reinstall the drivers for things like your wireless receiver. This is found on the Drivers disk, also gotten with your computer. Follow directions to recover all drivers are found on the disk.
Dec 13, 2009 | Toshiba Satellite A60 Notebook
My son inadvertantly caused Windows XP to crash; after reloading from the original 2004 disks my system no longer will recognize my E172FPb monitor; no matter how many times I remove and reload the driver...
Hi There: It sounds to me like it's your video card. Look for the drivers for it. This will usually happen if it is an after market card or the drivers are not on the drivers disk. If you have a disk for it fine. If not go to your device manager and see if it can find drivers for it. The fact the monitor is giving you lo res tells me it is working. It's just getting a lo res from the video card. I hope this helps, Jeff.
Jun 21, 2009 | Dell E153FP 15" LCD Monitor
My problem is the displayed windows on my monitor/screen
use your motherboard cd and install monitor and video card drivers..
please rate my suggestion..
Apr 12, 2009 | Microsoft Computers & Internet
Cannot get CPU to recognize Tatung LCD Monitor
When you reinstalled the drivers, did you reinstall the video card drivers? The drivers for your video card should be sufficient to power your display.
Mar 24, 2009 | Computers & Internet
Viewsonic monitor not detected after service
If you are running DVI-D(the white connector) then it isn't getting a digital handshake. If you have inspected the connection between the 2 and make sure there is no bent pins inside the connector that it mates with. If you have another computer, try to connect to that one.
Open windows start menu, right click on my computer, then choose properties. Next choose Hardware, then Device manager. Once there, double click on display adapters to see if installed correctly. If good, click Monitors. If good, then your video card driver must need reinstall or update as usual. Also do you have the correct driver for you monitor? How does it react when you uninstall the monitor driver(can you select 32bit and higher resolution in default drivers?
If none of this works, I would suspect that the replaced component failed due to static or faulty components within the electronics.
Is there any other changes to the PC (new video card, updated Directx9.0?)
Hope this helps and let me know if I can be of anymore assistance?
Aug 20, 2008 | ViewSonic Computers & Internet
My monitor is stuck in the lowest resolution
Distorted video after increasing the resolution in Windows. The resolution has been set higher than what is supported by the monitor, ... we recommend 640 x 480 with 256 colors or the lowest available setting.
Computer always boots into Windows safe mode. When booting into safe mode, the lowest settings are used, including your video card. This means that the resolution is 640x480, 16 colors when in safe mode.
Drivers & Downloads for your Dell Monitor Drivers & Downloads for your Dell Monitor ... Drivers & Downloads for your Dell Monitor
These's site click on them and follow instructions, Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell E173FPb 17" TFT LCD Monitor
ViewSonic VX1945WM LCD Monitor Logo
131 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
