SkyStar-2 polarization voltage
Hello to all,
I have a problem in my skystar2 I can not receivetransponders in the polarization H I measured the voltage of theconnector skystar and change to a transponder in H and the tension was13v. But in the polarization H should have 18v. The skystar does not send the voltage of 18V to switch the polarization of LNB. Does anyone know any solution?
Thanks in advance
Technisat - Skystar2 Rev 2.3
I have the same problem
Posted on Oct 11, 2008
HOW I CAN CHECK OIL LEVEL SENSOR
There s/b a finite resistance between pins 1 and 2. Even if this is so, the sensor can still be defective. I suggest that, if the dipstick shows full, and you're getting a Low Oil message, merely replace the sensor. It's a known, but rare, failure. You'll need to drain the oil, and replace the O-ring.
Continuity is used to check that a circuit is continuous, and not broken. It does not measure resistance. Example: an electrical fuse to see if it is truly blown.
Resistance is a measure of the impeding of current flow. In the case of the level sensor, the resistance element heats the sensor.
Diode test is to determine if a diode is defective; one polarity actually measures the junction voltage, and the other polarity shows nothing, which indicates that the diode is working.
If you want to know more, visit your local Radio Shack and ask for a book http://www.hella.com/MicroSite/soe/sites/default/files/downloads/J00137_Oelniveausensoren_GB_TT_korr1.pdf An Overview of Oil Level Sensors and How They Work
Apr 12, 2015 | Peugeot 206 Cars & Trucks
TechniSat SkyStar 2 eXpress HD
Force the windows 7 driver u till they come up with the newer one. Worked for a customer of mine
Mar 26, 2014 | TechniSat SkyStar 2 eXpress HD, PCI...
Fail capacitors how to replace
If capacitors are electrolytic types, then they have polarity + and -, and always are a mark on the pc board and it could be marked with either the "+" symbol or "-" capacitor has a mark itself that denotes polarity also, the most common mark i have seen is "-" running from top all the way down at a side of cap, you just have to buy them same voltage and capacitance rating and install them verifying TWICE the correct polarity and you are done, Mouser electronics has a wide stock of electrolytics, but remember polarity otherwise you will get a very big pop.
Oct 27, 2013 | Behringer BXR1800H Ultra Compact 180 Watt...
1970 XLCH generator. It s only putting out 1 1/2 - 2 volts. I have taken it totally apart and cleaned all contacts, trued the commutator, put it back together, with no better voltage. I am not sure I am...
F is field coil and D is output. With engine running, put battery voltage on to the D terminal for a few seconds and see if this kick starts the generator. I will assume that the regulator is working correctly. Next test is as follows. Remove the F wire. Engine running. Connect 12v to F connection and measure D connection. If low volts, connect F connection to ground. If still low volts suspect faulty generator. If volts come up under any of the two tests the regulator is suspect.
Sep 11, 2013 | Harley Davidson Motorcycles
How to set mastech multimeter to read small batteries
Set the multimeter to a DC voltage range that includes the voltage you wish to test. Connect the probes with the correct polarity and observe the reading
Mar 16, 2013 | Mastech 19-range Digital Multimeter Dmm...
CaNT FIND POLARITY SYMBOL ON WIRELESS_N_TRAVEL ROUTER
Use a multimeter to measure the voltage on the adapter plug and you can determine the polarity at the same time.
Sep 09, 2012 | Computers & Internet
Ac adaptor on one of my extension phones doesn't charge
Any AC adapter with the correct voltage and polarity will work on the extension phone base. They are low current devices, and the multi-voltage/polarity adapters at Walmart will work.
If you're good at measuring voltage with a voltmeter, you can often replace a cut or intermittent cord with an extra used adapter at most thrift stores ($1 usually).. It's usually easier just to buy one.
Good luck, and hope this helps.
Jan 19, 2011 | Cell Phones
On ge top load on the pump dose the black wire go on the left or right terminal
Hello Jim and welcome to fixya.
Whenever there are only 2 wires involved and dealing with "AC" voltages the polarity shouldn`t matter, as opposed to "DC" voltages when polarity does matter, but typically with those pumps the black is on the left, white on right.
That should be the answer to get you fixed up. Thanks for coming to "fixya". please take a moment to rate the information provided accordingly.
Good luck.
macmarkus :)
May 13, 2010 | GE WBSR3140DW Top Load Washer
Pc boots and stays on the black screan
The current configuration of the Skystar card is probably trying to use the same interrupt as your video or there is another hardware conflict between your PCI card and something else in the system. Boot into BIOS without the Skystar card in the machine and go to the PCI options. Tell it to reset the PnP information (actually happens on the next reboot). Exit and save the changes but shut off the computer without allowing it to boot up. Install the Skystar card and turn on the computer. The BIOS should reconfigure all of your Plug and Play hardware to automatically eliminate any hardware conflicts and the system should come up normally.
Jul 10, 2009 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
Kicker protection light won't shut off
Hello newwithtech,
There are 4 possible causes for the amp to go into protection mode. Kicker calls it SORT for Short, Overvoltage, Reverse polarity, and Thermal. If the amp has been in and working properly, it's probably not reverse polarity. And if it goes immediately into protection when power is connected, I'd rule out thermal. So it's probably either a short or overvoltage.
1) Start by removing the speaker wires and see if the amp powers up properly. If it does, one or more of the speakers is shorted or grounded.
2) Test each pair of wires with a multimeter set to the lowest resistance (ohms) scale. Measure across each pair and from each individual wire to ground. Across each pair, the meter should read about 3-4 ohms. From each individual wire to ground, it should read infinity. If the meter reads "0" ohms (shorted) in any test, you have located the problem.
3) If the speaker wires test OK, set the meter to read DC volts and measure the voltage at the amp positive terminal. If the voltage is higher than 16V or lower than 9V, you've located the problem.
4) If the voltage is OK, remove the RCA inputs and test for proper power up. If it powers up without going into protection, you have a shorted/grounded input. Replace them one at a time to determine which one(s) is/are defective and replace the cable.
If these tests show all the wiring is good and the voltage is OK, the amp is probably shorted internally (most likely an output MOSFET), and requires service at the component level. You need to take it to your local audio shop or send it to Kicker for repair.
Hope this helps.
Jun 29, 2009 | Kicker KX300.4 Car Audio Amplifier
Televison & Video Logo
171 people viewed this question
Top Televison & Video Experts
Electro Med Services...
