Question about Panasonic PV-GS31 Mini DV Digital Camcorder
Lcd screen black
Bought this puppy off e-bay. Everything worked when I test drove it. Next time around, the LCD screen is black. Image in eye viewfinder, plays back on computer, etc. HAve tried reset. Nothing in manual. Is there a button I'm missing? Is it repairable?
Thanks
  • 2 more comments
  • cameramateur Sep 20, 2008
    Thanks Viper, But it is the same on battery or AC. Yes, I checked the lens cap. It works through the viewfinder - all on-screen info is present.
    Off/on lcd screen makes sense. I found an lcd tab in menu, "lcd set". "yes" or "no.' Push YES, and got a couple of sliders. Can't leave it on YES, if that's even necessary...
  • cameramateur Sep 21, 2008
    IS there a lcd on/off particular to this model?
  • cameramateur Oct 05, 2008
    NEver heard from nobody "bout "where is the backlight on/off button.
    Thanks...
  • 6,487 Answers
IF you want you can try to reset this unit to bring everything back to its default settings if incase this is just some problem with the settings of the camera that is causing this problem...
Hope that helps.........
Posted on Oct 05, 2008
  • 70 Answers
Do you have it set to camera mode there is no power saving mode for it. it might be burnned out contact the seller of the camera and let him know whats going on because most likely youll have to return it i know that sucks
Posted on Sep 21, 2008
    Top Expert:
  • Panasonic Master
  • 77,202 Answers
What about the backlight for the LCD screen??
  • yadayada
    yadayada Oct 05, 2008
    There is no switch for the back-lite, it is part of the automatic battery saver circuit, this will require repair by an authorized repair station.
    Brigadier General:
  • 5,158 Answers
Go into the menu of that camera and look for the setting to turn on the lcd screen or turn it off... it's a battery saving feature on most cameras
Robert
Posted on Sep 20, 2008
    Master:
  • 505 Answers
Try taking battery out then back in also check to see if you don't have the lends cap on
    Genius:
  • 1,847 Answers
There seems issue with the data cabel that run to the lcd. this new and in warrenty . so return it .
  • Legin Varghese
    Legin Varghese Sep 20, 2008
    there is no issue with the camcorder the only problem is with the data cable, it runs thought the hinge. If you can open the unit to check for damage or it could be even be a loose connection.
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
DC280 Kodak Camera- Everything is working fine
Take the batteries out of the camera and let it sit for around an hour. Turn your dial to "set up", then put the batteries back in and turn the camera on, it should ask you to reset the date and time on the LCD. If it doesn't, your camera is essentially dead. Buy a new Panasonic FZ35 if you can afford it. Best All Around Camera I have ever had including the more expensive SLRs.
Mar 18, 2010 | Kodak DC280 Zoom Digital Camera
Hi. The LCD screen is black and won't take a photo...
This is a common problem... it is time to change the camera
Jan 19, 2010 | Sony Cyber-Shot DSC-P200 Digital Camera
Noticed screen flickering occasionally the last
Screen bulb burning out, bad inverter, or LCD wires crimped or exposed and touching each other and shorting out.  Have IT open this puppy up and look into it or you can do it if you got the tools and your handy. You can get a new screen on e-bay for around $150
Oct 30, 2009 | Sony PCGK37 Notebook
I dropped my garmin nuvi 760, it turns on, screen image looks like there is a "hole
You can find a replacement LCD screen for Garmin 760 in this link:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Categories/Garmin
I hope it helps,
Ignacio del Olmo
May 16, 2009 | Garmin Nuvi 760 Car GPS Receiver
Image blacked out on LCD and can not see image in view finder
Try this, it may or may not work. Insert the Video cable plug in and out of its slot a few times. The cable when inserted turns the screen off. But sometimes corrosion can build up on the internal plug switch, also causing the screen to turn off. Inserting and removing the cable a few times can sometimes knowck off this corrosion.
Mar 27, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Touch screen cracked - can it be repaired and how much will it cost?
Okay, first post was just a test to see if I could post before typing all this out.
This is for a Garmin Nuvi 760
First, you can find a new touch screen on E-bay for about 10 dollars. The LCD+touch screens are about 60. If you just cracked the screen but the display looks fine, you can just replace the touch screen.
Now, for do-it-yourselfers. To open the back of the case, there are 2 small torx (star) screws on the back to remove. If you don't have a torx driver, sometimes just the right size eye-glass screwdriver can fit but be careful not to strip the heads. Once those are out, you need to seperate the back casing from the front. I used an old credit card to pry gently with all the way around until it pops off. Don't force it, just be patient, it will come off.
Next, I recommend unplugging the speaker and battery so you can put the back aside for more room. There are 4 more phillips screws on all 4 corners of the circuit board. Take those out and the board comes out relatively easy. Don't force it. Once it is loose, there isn't much room to play with because of the ribbon cables. The large one is the LCD, the 4 pronged one is the touch-screen. There is a lever that lifts up and secures them in place. I got away with leaving them connected, but they are fragile and easy to tear. Next is separating the silver plastic part of the case from the black front that goes around the screen. I pried a bit with an eye-glass screwdriver around the area where the earphone jack and memory card go in. Again, using a credit card to pry all the way around is best that it won't leave scratches. Don't force it, just be patient.
Once you have that off, remove the screen from the case. I did it by pushing with light-moderate pressure all around the edges massaging it out. The touch screen and LCD have a rubber/leathery thin tape going around the perimeter. On the front, I got under it with an eye-glass flat head screw driver and slowly worked it around until it was free, being careful not to tear it. On the back, I used a razor-blade to un-stick it from the LCD, but be very careful not to damage the LCD screen if it's still working. The goal is to get this off in one piece. Once you have that off, there is the LCD and touch screen with double-back sticky black tape holding them together around the edges. I used a razor-blade. VERY CAREFULLLY separating them. Once that was done, I carefully scraped the remainder of the tape off the LCD which was un-reusable. I didn't know what to use for putting the new screen on since I didn't have that special type of tape, so after raiding my tools, I found some rolled butyl rubber for installing windshields. I cut small pieces of this off and put them around the perimeter of the new touch-screen (VERY THIN) in the same place the old one was, as if I was installing a real windshield. This took much patience, but in the end it worked great. Before putting the new touch-screen on the LCD, I blew it off with some compressed air, being careful to never leave a fingerprint on it while working on it. After putting it on, I pressed softly but steadily to get the rubber to even out so there wasn't any high points. Then, I replaced the same sticky tape that went around the perimeter of the 2 screens the way it was. It wasn't as sticky, but I made sure it was in place and it kept there by the pressure on the sides of the screen casing. Make sure you get it on right, because I think it's there as a shock-absorber so that the screen doesn't break as easily if dropped or jarred. I plugged back in the LCD screen into it's corresponding place on the circuit board and closed the tiny lever that secures it in place. Then comes putting everything back the way it was in reverse order. Be careful and go slowly, I ended up accidently pulling the ribbon cable out for the LCD and Touch screen and had to go back and reconnect them. This is a good time to attach the battery and turn the GPS on to see if you have all your connections made securely before everything is fully together. Put everything back together in reverse order, remember, if you have to force it, then don't. Don't forget to hook the speaker back up.
When it's all back together, if the new touch-screen doesn't tap where you tap it, you can calibrate it. This can be done by turning the unit off, then turning it on, then IMMEDIATELY switch it to the right(lock) position before it boots up and hold your thumb on the screen for about 30 seconds. There will be a callibration routine that will tell you to push dots on certain parts of the screen. If you do this with a stylus, it will probably be more accurate.
Now hopefully, you will be more careful and not drop your nuvi again. I hope this helps.
Sep 27, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
The view finder does not wotk
Try pulling out the eyepiece, it will reveal a switch that controls the focus, it maybe the problem, good luck
Aug 13, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Panasonic PV-GS31 Mini DV Digital Camcorder Logo
97 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
