2005 Mitsubishi Endeavor Logo
Anonymous Posted on Oct 03, 2011
Adjusting the parking brake on a MiTSubichi ENDEAVOUR 2005
brian soufane
Level 3:
President:
  • Master 693 Answers
  • Posted on Oct 03, 2011
brian soufane
Master
Level 3:
President:
Answers
693
Questions
Helped
511838
Points
4903
If your parking brake is too loose or is not properly adjusted, you may encounter problems while parking, positioning and driving your car. Most of the time, car owners would send their car to a mechanic in order to fix and tighten the parking brake. However, you can actually skip this step and adjust your parking brake yourself. When your car starts to slip on a hill in its park position, you need to start tightening the parking brake.1 Remove the car's center console cover placed around your parking brake level inside your car. This is found between the seat of the driver and the front passenger.2 Use your wrench to turn its adjuster nut found at the end of your parking brake's cable rod. Loosen the adjuster nut with your wrench, while making sure that it does not come off at your parking brake cable rod's end.3 Raise your car rear wheels using your jack, and use your jack stands to support both its rear wheels.4 Pull up your parking brake handle up to two clicks or notches. Tighten your adjuster nut until you feel a slight resistance on your rear wheels whenever you spin them.5 Release your parking brake lever. Check and make sure that your rear wheels are still able to spin freely and without any resistance.6 Pull up on your parking brake lever up to three to five clicks or notches, while making sure that your car's rear wheels are not turning at all.7 Lower the car by adjusting your jack, and remove your jack stands from your car's rear wheels.
  • Jerry Conners
    Jerry Conners Sep 25, 2015
    Brian, If you don't know what you're talking about, then stop answering questions!. As Izek said, it's a foot brake and whats even dumber, 2 people liked his answer and it's WRONG AND ZERO HELP!!! LOLOLOLOL
  • Tra Steed
    Tra Steed Sep 29, 2017
    its the same procedure even if your have the foot brake. the adjuster is under the center console just as Brian said and the steps tp adjust are also what Brian said. Sooooo..Jerry are you still feeling so smart?
Izek Shteinberg
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 27, 2015
Izek Shteinberg
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
6979
Points
18
It's a foot parking brake, not hand brake. Dahh
Adjusting the parking brake on a 2005 saturn reley
The first step ALWAYS to adjust the REAR BRAKE SHOES. The parking brake should not go "out of adjustment" UNLESS the rear brake shoes are:
1. Worn
2. Have recently been replaced and not set correctly
3. Are out of adjustment due to wear.
Turning the adjustment nut (unlike what Autozone seems to imply) is the LAST thing you should do AFTER all other possibilities have been eliminated.
Adjusting the rear brakes can often be accomplished easily in an empty parking lot. Simply accelerate in REVERSE to about 5~10 MPH and stomp on the brake pedal. Repeat this 3~5 times. You will often discover afterward that your forward braking performance has suddenly improved and that Parking brake is now miraculously "back in adjustment."
Emergency brake adjust
the park brake may have to be adjusted separately. if you have disc rotors on the rear . If drums then you will have to adjust the brake shoes up manually to start with
Parking brake 2005 elantra does not work
Hi Richard, I think you may find that the park brake works on a separate system with a set of small brake liners inside a drum on the rear wheels. If I'm wrong and it uses the disc pads, try replacing the pads and adjusting the travel, that should sort out the problem. Regards John
1helpful
How do you adjust the parking brake on a 2005 buick lacrosse
Under the vehicle you will see a cable coming from both back brakes to a "t" in the middle of the vehicle. Tighten the cable till there is almost no slack by turning the nut on the bracket. Click the parking brake one or two clicks and then remove the slack until the cable is barely tight. Now your parking brake is adjusted properly.
I changed the shoes on the Parking brakes on my 2005 Escalade EXT, adjusted the shoe adjusters so the shoes "just" drake when the drums are re-installed, cleaned and re-lubed the mechanical cylinders,...
The first time you use the brakes on a drum the shoes will equalize with each other. This may be the reason it doesn't seem adjusted right. Readjust the shoe adjusters till you can just hear the scrape and try again.
2helpful
Hi, I have a 2005 tucson, i applied my handbreak yesterday in my driveway and now it won,t fully release. back wheel is making a noise when i go forward. my question is, do i have to replace it or can i...
YOU NEED TO ADJUST REAR PARKING BRAKE AT THE LEVER.FIRST OF ALL YOU NEED TO BLOCK FRONT WHEELS.THEN RAISE THE REAR OF THE VECHICLE.SUPPORT WITH JACK STANDS.MAKE SURE YOU ARE ON HARD LEVEL SOLID GROUND WHEN USING JACK STANDS.AFTER RAISING THE CAR SET PARKING BRAKE 1 CLICK TOWARD ENGAGEMENT.REMOVE FLOOR CONSOLE.TIGHTEN THE ADJUSTING NUT UNTIL THE PARKING BRAKES DRAG SLIGHTLY WHEN THE REAR WHEELS ARE TURNED.RELEASE THE PARKING BRAKE COMPLETELY.CHECK IG PARKING BRAKES DRAG WHEN REAR WHEELS ARE TURNED.READJUST IT NECESSARY UNTIL THERE IS NO BRAKE DRAG FROM THE PARKING BRAKES.
How do you adjust the emergency brakes on a 2001 f150 supercrew?
If you have disc brakes, there is no adjustment and the emergency/parking brake as no effect on pedal travel. The emergency/parking brake uses regular drum type shoes working in a small drum inside the rotor and is independant of the service brakes.
2helpful
Rear rotors stuck on e brake shoes. Tried turning off, hammering off, loosing the e brake adjuster. The pins look broken holding the shoes on since the bottom part of the rotor pulls way out but can't get...
When i did my brakes on my 05 grand caravan i turned the parking brake adjuster and hammered like crazy till they came off then i replaced parking brake shoes and hardware they are never saved and after you have replaced that you need to adjust parking barke shoes.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
