Question about Refrigerators
Maytag refrigerator icemaker door won't open
Trying to remove front door cover for ice/water dispenser Maytag refrigerator model RSW24E0 to replace solenoid.
Chuck
  • Anonymous Jan 30, 2009
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
  • 2427 Answers
SOURCE: Ice Dispenser problem on KitchenAid KSCS25INSS00 Refrigerator
You can download the repair manual or service manual for you Kichen Aid which you can find by using goolge just type
SERVICE MANUAL KITCHEN AID (model) Brand
and google it
here is a useful forum that contais extra information and some quick fixes http://www.applianceblog.com/mainforums/showthread.php?t=7374
Posted on Jan 02, 2008
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
I had two (2) broken wires in the harness. I don't think you actually have to take the door off. It may be a little cramped working, but I think it can be done. Once you take off the bottom grill, find the end of the harness next to the water filter and unplug the white plug. Just below that is a ground wire. Remove the screw and take the green wire off. Then, next to that is a white "c-clip" holding the harness against the bottom of the refrigerator. Remove that clamp and you should have enough "play" to work on the harness. (It is probably a pain in the #*@ to remove the entire harness because it runs into a hole in the bottom of the door and then up through the door itself) You'll have to cut away the black mesh sleeve over the harness. I cut it with a pair of wire cutters as close to where the harness goes into the door as possible. There may also be a bit of black electrical tape at the end of the mesh closest to the white plug. Remove that, and you should be able to slide the mesh sleeve off, over the plug. This should reveal the broken wires. I just took some 12 gauge braided wire and cut a couple of pieces
Posted on Jul 26, 2008
SOURCE: Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
Posted on Sep 23, 2008
tech master
  • 120 Answers
SOURCE: Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Posted on Oct 12, 2008
The front panel will not change on the touch pad It appears to be stuck on Ice and will not change to water. Where do I begin to repair the problem?
You may need to replace the touch pad. The part that you removed from the front can be ordered on searspartsdirect.com. Just type in your model number and look at the Dispenser parts diagram to find and order the part.
Jan 07, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Just recently noticed the icemaker was not making ice. I checked to make sure the water was on (we are getting water through our water dispenser). I checked and there is no ice in the icemaker. Do I...
pull off cover in front of icemaker, there should be 2 hole under big gear labeled t and the other labeled h, jump those 2 with an insulated jumper wire, icemaker should run through complete cycle, pull out jumper wire at about 11 oclock on big gear, if goes through complete cycle and fills with water, ice maker is good, if not replace ice maker
Aug 21, 2010 | Maytag MSD2756G Side by Side Refrigerator
No ice
Remove the back of the unit, remove the water valve from under the unit without damaging the water line. trade the wires that connect the valves. depress the water selector at the dispencer. if you hear water flowing, replace the dual water valve. You have to achive 15 degrees to cycle the icemaker but in most cases you can lift the bar on the icemaker for 3 minutes and then lower it to cycle the icemaker. If you remove the front white cover from the icemaker , then force clockwise movement on the large cam, the icemaker will then cycle. It requires only a very small amount of force to start the movement. If it doesnt cycle, replace the icemaker. If both the icemaker cycles and the water valve operates,you will need to call a qualified tech to correct the temperature problem if 15 degrees is not achived.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool refrigerator with an ice maker and when the icemaker is filling with water it leaks from the front of the tray into the ice storage bin.
1. icemaker is not level. (check and re-level)
2. icemaker has a crack in the mold.(replace i/m)
3. Water level set too high.(remove front cover and adjust water level screw counterclockwise)
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Apr 09, 2009 | Maytag MFI2568AE Side by Side French Door...
Not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Jan 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator ice getting all stuck together in one big piece looks like there is some water dripping in the ice box, I have changed the water...
Refrigerators Logo
517 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
