Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Assistance i have a washing machine from hotpoint WD440 when i turn it on the power light keeps flashing and when i press the start button it does not work please what should i do to fix it up thanks Teejay
    Problem Solver:
  • 5 Answers
The door switch may be faulty, as a safeguard the machine will not start if the door is not closed properly or this part is faulty. You can check this by pushing the door firmly in or (unplug the machine first) removing the front of the door seal and putting your hand around the corner where the door latch goes into.
The door switch only uses a live and neutral so you can bypass it by taping the two wires together, make sure they don't touch the cabinet, replug the machine then put it on a spin to test. This is a cheap repair, just don't use the machine with the door switch bypassed like that, you could have a flood!
Posted on Oct 23, 2008
I have a hotpoint wd440 washing machine. The on and off but just keeps flashing and wont stop.
Dean Wright is spot on. I followed his instuctions and the problem was solved. Thank you Dean you are a diamond!
Apr 27, 2012 | Hotpoint Washing Machines
I have a hotpoint wd440 and lights 1,2,3,4 and the dryer & the on/off button are all flahing.
For Indesit ( Hotpoint, Ariston) 'WD' washers, those flashing lights stand for 'dryer heater relay' according to my list of codes. It COULD be just poor electrical connections which are causing them but it requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 06, 2011 | Washing Machines
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
Feb 03, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
237 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
