Question about Dell XPS 200 PC Desktop
The size and print is too large. Half of the document runs off the screen
The print of the letters and screen is too large. Half of the documents runs off the screen. I went to control panel to make it smaller but it didn't work.
  • danpaulcam Dec 10, 2008
    I have the same problem as mentioned above. My print suddenly is very large and I cannot read the entire window without scrolling up and down and left and right. Help. My two-year old did this.
    Scholar:
  • 32 Answers
You should be able to place your mouse in a blank area of your desktop then right click. Then click on properties. Then click on the settings tab. Under this tab there should be a place to change your screen resolution. Change it to 1024 x 768 if it is not already there. If it is there then go to a higher number with the slider.
I hope this helps. If not, please let me know.
Posted on Sep 20, 2008
Won't print large font in solid black. Only prints outline of letters in black
Try resetting word to factory settings to clear all the settings, Then make a new document and type whatever you want with the font size you require, save then print, see what happens.
Mar 10, 2015 | Office Equipment & Supplies
The page i insert for scanning is small but the print of the scanned document is large. how?
if you are using word open up word select view from the drop down list select toolbars select standard ,formatting
also open up word across to the left you will see arial times new roman arial black next will be more to name a few of the different languages from the drop down list your documents will be read in
also next to that will be a drop down list with all sizes you can change the sizes of text
open up a document you should a number of tabs at the top of your screen you should see a number with % percentage with a drop down list which has many zoom increases
hope it helps
Jun 06, 2012 | Epson T073n Ink Tx110 Tx210 Tx410 Tx550w...
I have a Dell 3130cn, just bought a new CPU with Windows 7, running Word 2007. Only getting a 1.5" strip of the picture on one end of 8.5x11 paper. Downloaded 64 bit driver (I believe) but not...
Lets see if we can't figure out what could be causing your printer to print a small strip like that.
First thing to check are the current settings on your printer to see what size of document it is printing. The best way to check settings are from inside a microsoft word document. So open or create a word document and then click on file (or the round globe at the top left of the screen) and slide down to "print" and click on it.
When the printer screen opens, click on "properties" next to the name of your printer. This will open the area that controls the type of document, size and quality ect which are your current settings. Click on "paper quality" tab at the top left of the screen and check the size and type of document that is set. make sure that all settings are for letter size 8 1/2" x 11".
Next click on effects and make sure that it is set to print on letter sized documents (same as above).
If all settings are correct, then open a word document and click on file (or the round globe at the top left) and then slide down to print - but don't click on it - instead slide over to print preview to open up a preview of the current settings.
Tell me - do you see the full document in the print preview? If the document looks the way that it should then we can be sure that its not the settings causing the problem.
Next thing to do is disconnect the usb cord from the pc, and then open your control panel and go to printers and delete the current printer.
Go to Dell's website (www.dell.com) and click on drivers and software and enter the name and model of your printer and download the whole software package that includes the drivers and everything.
that should solve your issue
Apr 27, 2011 | Office Equipment & Supplies
Change legal size to letter size
scan it as a document, re-scale it in required size and save then print in required size.
these adjustments are in your word or office programs. if you need to make it to copy, insert your original in the scanner, in paper tray insert your letter paper, select copy and then re-size, this should do it "on the run".
Jul 26, 2010 | Dell 1815dn All-In-One Laser Printer
I want to know how to increase the size of my fonts on my printer . where the computers fonts are large enough when I print out aany thing it is small I have a lexmart x 5070
iterry,
The font size is controlled by the application, whether it be MS Word, Excel, or whatever.
If it is Microsoft Word, then:
1. Open a document
2. Select [Select All] from the [Edit] menu option
3. All text is now highlighted.
4. [Format] [Font]
5. Select the font Size, etc.
6. Print it out.
You may not want to "save" this document.
Do the same for other documents, etc.
Nov 09, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Scanned documents too large
When you scan them, save them as a different type of document. Try saving them as a web document. They will reproduce almost as good and will be a lot smaller in size (bytes, not inches).
Oct 26, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
How can i get this printer to print larger letters
Usually, the size of the letters depend on how large you have them in your document. Open your document, highlight the letters you wish to change (or the entire document if you want to change everything) and from the menu bar at the top of the screen, (Usually under "Format") you will find a "Font" selection. Increase the size of the font by selecting a larger number. This will change it on your screen as well as when the printer prints it. You may have to save the changes before printing.
May 14, 2009 | Lexmark C533DN InkJet Printer
Dell XPS 200 PC Desktop Logo
66 people viewed this question
Alun Cox
