Question about Cameras
Chinon 35mm manual focus SLR, Shutter won't work, batteries are new
  • jonadam76 Sep 20, 2008
    I don't know what or where the percussion screw is. Also there are no information lights illuminated when looking through the viewfinder. The camera has not been used for 6 years.Thank you in advance. PS When I first selected auto the shutter operated once only.
  • Cameras Master
  • 1,879 Answers
@ronaldsuboc
percusion screw ?
Posted on Sep 20, 2008
  • Cameras Master
  • 19,396 Answers
Try first removing the film and loading a new one, if the film is stuck or at the end shutter may not work.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!!!!
may be the shutters stuck
try open it use the percusion screw
but becareful open the part is very too small
place it in a cup or drinking glass try to
locate the switch or shutter it might be stuck
try to clean if there is an dust or dirt that prevent
shutter to work!!!
    Brigadier General:
  • 6,966 Answers
Initially, assuming a power problem, pls try to clean the battery contacts. In some instances, it may be necessary to scrape them clean or bend/stretch so as to provide more pressure to the batteries.
Otherwise, pls post back other indications, observed conditions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 20, 2008
    Incidentally, I was made to understand that there is a shutter release lock that is built-in to the main switch, you may want to look into that as well.
    Or could you at least perform a battery test? ( set main switch to S or C and partially depress the shutter button). The shutter will not engage if the AF is not solid in an AF mode.
I would like to know if a 24mm Nikon f2.8 Ai Manual Focus Lens will work on a Nikon N75 SLR Camera
Yes and no. It will fit and you can take pictures with it. You'll have to focus manually, of course, and you won't get any exposure help from the camera's light meter. You'll have to use the camera in the Manual exposure mode, setting the shutter speed on the camera body and the aperture by turning the ring on the lens and, as I said earlier, without any help from the camera's light meter.
Mar 17, 2012 | Nikon N75 35mm SLR Camera
I need to know if a Canon EOS 10s 35mm SLR camera has a manual option for the shutter speed and aperture
Yes. Turn the command dial to the "M" position.
If you need a manual, you can download one from
http://butkus.org/chinon/canon/canon_eos_10s/canon_eos_10s.htm
Aug 28, 2011 | Canon EOS-10S 35mm SLR Camera
Hi i have a Vivitar film camera, V3800N I lost my handbooks and i dont know which knob or dial is the one to adjust the shutter speed.... can anyone help me?
The big knob with all the numbers next to the shutter release.
You can download a manual from
http://butkus.org/chinon/vivitar_cameras/vivitar_v3800n/vivitar_v3800n.htm
Oct 03, 2010 | Vivitar V3800N 35mm SLR Camera
How do I change the shutter speed on a Nikon EM film SLR
The EM doesn't really have a manual shutter speed setting. It does have a Bulb setting for long exposures and a 1/90 second manual for flash, but otherwise the camera automatically sets the shutter speed to go with the currently selected aperture.
Normally you would set the aperture and let the camera set the shutter speed. You can adjust the shutter speed by pressing the exposure compensation button for +2 stops. You can also adjust the exposure by changing the ASA/ISO setting.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_em/nikon_em.htm
Jun 29, 2010 | Nikon EM 35mm SLR Camera
How do you set shutter speed on a nikon n70
In Manual exposure mode, you can change the shutter speed by turning the command dial on the back of the camera.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_n70/nikon_n70.htm
Jun 14, 2010 | Nikon N70 35mm SLR Camera
I don't know how to open the camera to put my film in...
Press the shutter release button to ensure that the shutter is released, then pull up the film rewind knob until the back pops open.
If you need a manual, you can download a PDF one from http://www.butkus.org/chinon/ricoh.htm
Mar 24, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
HOW TO GET STARTED WITH NIKON N65, I DO NOT HAVE A MANUAL. HELP PLEASE.......TNX.
Basically, you insert batteries, load film, attach a lens, point the camera, and press the shutter release button :-)
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 11, 2010 | Nikon N65 35mm SLR Camera
Does the minolta xg-a have to have batteries to use the view finder? if so, what kind of batteries does it take
The XG-A requires batteries, not just for the viewfinder, but also for the shutter. It uses two alkaline A-76 (or equivalent) or two silver-oxide EPX-76 (or equivalent).
If you need an owner's manual, you can download a PDF version from http://www.butkus.org/chinon/minolta.htm
Feb 16, 2010 | Minolta XG-A 35mm SLR Camera
How do you turn on a sigma SA-7n film camera??
I don't know about the SA-7, but the SA-5 doesn't have an on/off switch as such. Pressing the shutter button halfway activates the autofocus and turns on the light meter. The camera switches off after six seconds of inactivity to conserve batteries, though the shutter can still be released accidentally. Turning the mode dial to the "L" position will lock the shutter and prevent accidental release.
You can find a manual for the SA-5 at http://www.butkus.org/chinon/sigma.htm . It's not ideal, but it should help you get started.
Dec 25, 2009 | Sigma SA-7 35mm SLR Camera
My new cannon rebel isnt working, the lens will focus but the screen is black. cannot get the shutter to activate
Mirror mechanism is locked up and probably out o synch with the rest of the shutter cocking mechanism. sometimes there is enough power in battery to focus lens, but not enough to power the winder/shutter/miror mecansim- check the battery
Aug 24, 2009 | Canon EOS Rebel G 35mm SLR Camera
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
