Question about Xerox Office Equipment & Supplies
XEROX Work Centre C2424 has error code 07,010.43:1559
    President:
  • 2,072 Answers
That is a code that comes up when the print head is not piviting properly.
The 2 main causes are , 1 there is a stainless steel block on the left side of the machine which gets ink spilled into it, it needs removed and cleaned, the other issue is if there was a power failure or the machine was inproperly shut down, the wiper blade that cleans the print head between copies is stuck between the drum and prine head.
Let me know if you want to try and fix this. Its not to hard, Just somewhat time consuming.
there is a 90 percent chance one of those 2 things is causing your problem.
Posted on Sep 20, 2008
Xerox c2424 error codes
Drum disconnect. The drum heater is not drawing the expected
power from the supply.
AC power supplied by power sources such as uninterruptible power supplies (UPS's) or DC-to-AC inverter systems, may not supply enough current to properly power up the printer. In these cases, the printer may report printhead jet-stack or reservoir
heater disconnect, drum heater, or preheater errors (37,002.47 thru 37,012.48).If you do not hav a UPS connected then probably it is the drum heater problem
Aug 05, 2014 | Xerox C2424 Copier
Xerox C2424 error code 19,003.48 and 07,010.43
for error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
click on this:
for maintainance
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_maintenance.pdf
for troubleshooting:
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_trouble.pdf
Jan 30, 2008 | Office Equipment & Supplies
Xerox c2424 37,002,47:280890
The 37,002 error code is for a defective heater in the printhead 650-4354-00. There is no reset or workaround for this error.
Unfortunately, the part is fairly expensive, but the C2424 is such a workhorse, you may want to repair it.
Whit Item, Inc.
Dec 06, 2010 | Xerox C2424 Copier
C2424: error code 19,993.48:88868
This error is a Printhead error, but in this case is usually more probable to be caused by the Electronics Module.
The Printhead part number is 650-4354-00
The Electronics Module is 119-6427-03
I suspect the actual error code was 19,003.48
Whit
Item, Inc.
Oct 03, 2010 | Xerox C2424 Copier
Xerox c2424 has error message "Waste Tray Missing". Have emptied waste tray which was overflowing and placed it back in machine but above error message means it will not work.
The Waste Tray Optical Sensor 119-6487-80 is probably bad, which contributed to the overflowing ink. Look at the diagram #6
Whit
Sep 10, 2010 | Xerox C2424 Copier
I am receiving error code 39,012.40:76243 on C2424
Replace document feeder. 004k07270 $390.00
Sep 04, 2009 | Xerox C2424 Copier
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox c2424 Printer won't work
34 codes are related to the print head. Print head NVM or the print head itself. Most likely, I would say 95 percent chance of a print head failure.
Mar 01, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox C2424 problem (11,009:46 and 13,008.47)
The second fault is a result of the faulty electronics module. It is a print head heat related issue.
Question is, is the print head also faulty.
That electronics module is very expensive.
But the 11,009 specifically is a failure of the electronics module.
Have had those codes a couple of times.
Most likely the 50 volt source has failed, that maintains the print head heat.
A Drum Assembly thermal error has occurred. The following troubleshooting procedures apply to these errors:
arrwup.gif 13,008.47 The Drum Heater is too hot
Jan 30, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
199 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
