Question about Frigidaire CWS3600AS Top Load Washer
Loud noise in spin cycle
My washer makes a loud noise in spin cycle and leaks underneath, did the belt come off or is it the bearings?
  • wisewonders Sep 20, 2008
    we just ended up buying a new one:(
    thank you though for trying to help us
  • 116 Answers
Most leaks are associatd with your drain pumps although it can leak from the tub. If its the tube the seals in it are worn if it the drain pump - the first point to check is where the drain hose connecs to the pump otherwise you may need to replace the drain pump
The noise - if its what i am thinking of starts just as the spin cycle stsrts and just as it finishes - usually a clutch problem - worn - parts need to be changed.
Regards
Posted on Sep 20, 2008
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Entering test mode
1) try to go the instr. manual and go to the section troubleshooting they explain this . However if you do not have it download from .
www.manualslib.com
see this causes and fix it.God bless you
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch Assembly If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drain Pump If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Sep 30, 2012 | Washing Machines
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
When the washer is filling a loud noise is coming from the motor, it sounds like a bearing is going out. It seems to do it mainly when the washer is draining, but it starting to make the noise through the...
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings. Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.) Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub. Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water. Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers. Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Thanks for contacting fixya.com
Nov 11, 2009 | Fisher and Paykel GWL11 Top Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
205 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
