Water falled on my lcd screen
One night due to heavy rain some rain drops are had fallen on my lcd screen through the window .From that situation onwards a white flash is appearing at the botom.Iam unable to see the taskbar .i showed to a mechanic .He said that the pixels are burned and it canot be repaired.
is ther any solution to my problem.please answer
thank you
    Scholar:
  • 188 Answers
I'm sorry to say that the LCD monitor may not be repairable. For the time being you may be able to drag the taskbar to the right side of the screen. Left click on the tool bar and drag it to the right. Even if you can't see the taskbar it should work. I hope you can replace your lcd display soon.
Posted on Sep 20, 2008
Lots of rain water leaking into front passenger foot rest.
Are you certain it is rain water? It could be condensation from the A/C coil that fails to drain out of the drain pan, or possibly coolant from a leaking heater core. If you are certain it is rain water, depending upon the age of the vehicle, and possibly some other things, here are the possible options:
  1. Leaking door gasket.
  2. Leaking windshield seal due to rust
  3. Leaking windshield seal due to improper installation
  4. Leaking windshield seal due to acoustic (sound) over pressure (if you have extreme sound system with heavy bass)
  5. If you have a sunroof, if the drain hose comes down the passenger side door column, it could be leaking into the passenger compartment rather than drain through the floor pan.
Oct 29, 2015 | Cars & Trucks
Water leaks onto the passenger floorboard during heavy rain
Floor plug or plugs have fallen out most likely.There Should be some plastic plugs under the floor board outside. Look to visualy check to insure they are still in one piece.
A busted heater core will flood the passenger side floorboard when the heat is turned on.
Feb 22, 2011 | 1997 Ford Escort
Black Screen
Unfortunately you LCD screen has been damaged due to the heavy fall. The only way to sort out is to change the lcd panel but as you know this might prove expensive. Hence you will need to take your phone for an estimate to the nearest friendly mobile service centre and get a quote. If you can ask them to put in one which has been salavaged from another it might be helpful and cheap, So try this out and hope you get lucky. Good day
Jul 27, 2010 | Pantech Matrix Cell Phone
Sunroof leaks when heavy rain. no visible sign of
Check for a drain hole around the sunroof and spray the rubber with spray can silicone spray to soften the weatherstripping so it will be easier to seal
Jul 13, 2010 | 2003 GMC Yukon XL
I have water on the floor in the back on the passenger side, any solutions? Heavy rain one day, and not driven that day, bailed out the water, sat over night in the rain, another puddle (about 2 inches...
There are not any current recalls on this issue and I have not seen any particular issues on this year/make/model I do need to ask if you have a sun roof?
could be that the drains are plugged
either that or you have a seal issue, maybe the door(s) or window
to test, just simulate the situation
have someone stay in the vehicle while you hose the vehicle off without any attachments
spend time and do not move the hose from each section for at least a few minutes while you ensure there is no water instruction
let me know if I can be of any further assistance
Apr 19, 2010 | 2008 Dodge Caliber
Dropped phone now light won't come on for the face of phone
Hi, if the phone you are talking about is this RAZR V3, then what you have is a flex or screen problem. It either the flex is disconnected from the board panel or screen because of the sudden fall, or that you have damaged the screen itself due to the sudden fall.
In both situation, you have to take the phone to a repairer to diagnose which one of the problem is and fix it,,,
Take care
Apr 16, 2010 | Motorola Mobility RAZR V3
The lens on my nikon coolpix s210 just goes in and out a few times then says lens error and will not do anything else ? please advise - thanks !!!
If you've recently dropped the camera you may have lens damage that's preventing the camera from powering up. If it hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 27, 2009 | Nikon Coolpix S210 Digital Camera
CTS-V: Drive shaft "whip" or bad vibration in heavy rain.
Sorry I don't have a solution, just adding that you're not alone...
I just bought my '05 CTS-V on 8/31/09 and today (9/4/09) was the first time I've driven it in the rain. When I hit hard rain it sounded as if the tranny or rearend was going to fall off. I thought I had thrown an axle being or jacked up the tranny/rearend gears or something. The sound quieted down as I left the heavy stuff and then totally disappeared when I got to a dry area. One person said it was probably water hitting the undercarriage or wheel-well, but this was more than that. This sound was louder tan that and is not normal splashing water. If this noise was common, there'd be a heck of a lot more CTS owner complaining about it. I've never heard such a noise in any car I've ever been in when driving in the rain. I'd love to know what it was. I'm not even sure how to show or explain the problem to the dealership in order to get it fixed
Aug 18, 2009 | 2003 Cadillac CTS
GE air conditioner with air louvers on top of case - problem?
Most fan motors are allergic to water. You should carefully examine the places where rain could go and decide whether GE has sold you a risky situation. After all, they have left it up to you to make the decision.
I wouldn't buy one with openings on the top and I wouldn't keep one after GE has demonstrated that not responding is the kind of help you will receive.
Jul 22, 2008 | Heating & Cooling
Laptop problem
the water damaged the screen ....no way i know to fix it sorry :(
Jul 14, 2008 | Computers & Internet
Computers & Internet Logo
355 people viewed this question
David Payne
David Payne
