Question about Hotpoint Ultima WF860 Front Load Washer
Error code F-08
Hi Mikewigg. Did you sort your problem with the error code? I have the same code (following a burst pipe near the machine) and wondered what the diagnosis was. Can you help?
Thanks.
  • doru30 Nov 07, 2008
    f 08 is displayed on screen in the middle of the program. i have an indesit model wie 127.also when f 08 appears i hear a sound like something in running continuous (pomp or something)
Hi
Did you fix this? I have the same issue.
Posted on Oct 22, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
What is error code 6 on krups ea850b10 means?
Error 6 means machine thinks it has a leak in one or more of the following
1) Distributor
2) Thermoblock
3) Pump valve
4) Pipe leakage
Repair will involve specialised tools and parts, not really the sort of job to attempt yourself. Contact Krups and get from them contact information for your local service agent.
Aug 03, 2015 | Krups Small Appliances Espresso Machine
F1 08 f2 08 f3 08 f4 08 error codes vulcan comfort control what does it mean
What sort of machine is it? Refrigerated, Ducted, Gas? To do a full reset correctly, you must switch off at the main isolator next to the unit or at the meter box and leave it off for at least 15 minutes. A quick on / off does not reset it properly. If the unit is a refrigerated split system , and the outdoor is running but the machine is not blowing cold outside and hot inside (On heating mode) It could be due to a gas leak / shortage.
May 26, 2015 | Heating & Cooling
I have a problem for my machine canon Image runner 2520 error code E000010
Hi
There appear to be several causes for this code and others with a second set of digits. The following site lists the error codes and possible corrections for your machine :--
Error Codes Canon iR2520
Each code can be viewed individually by using the drop down menu "Codes", and you can also get a Service Manual pdf (format) from this site for a small charge using the link near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 11, 2015 | Canon Office Equipment & Supplies
I HAVE ERROR CODE F14 IN MY TOSHIBA e-studio 166 how i can reset this code
Jun 08, 2011 | Toshiba e-STUDIO166 Printer
We have a Whirlpool Duet HT washer. Due to the freeze, and burst pipes, we haven't used it for a few days, but got the cold water line fixed. However, when we started the washer, it came up with an F20...
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you do not have the hot water line fixed, then that is where your problem is. The washer looks for water supply on both lines. It will still work, but you will get this error.
Feb 06, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Problem with printer error # 1203
Unplug your device and replug it after sometime. Now run Reginout scan and reset your machine. Hope it would help you. Thanks
Dec 13, 2009 | Lexmark X2500 All-In-One Printer
Error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Dec 02, 2009 | Indesit W 123 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
172 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
