Question about Sharp AR-5320 Black and White Copier
Sharp AR-5320 Copier giving L 4 error alternately
I have a Sharp AR-5320 Black & white Copier. Mostly on first print It gives L 4 error blinking alternately. it start the printing process but when the document goes inside the copier it stop the printing process and on the screen L 4 blinking alternately. I am using my copier as a printer too. It also gives the same error when I print any document form my computer. Some time before I Installed new drom, Cleaning Blad and Tonor Cortradge. Although when I restrart my copier or run the #,Intrupt,C,Intrup+14 Programe it becomes good but I want to remove the mentioned problum. Any one can help me?
  • Sharp Expert
  • 1,326 Answers
The only way to corret the problem is to replase the fixing unit... That is what the L4 is refering to. It is not reading the correct tempurture..
Posted on Sep 22, 2008
SHARP AR 5320 PHPTO COPIER ERROR H-4
fuser error which could be a number of issues , press green copy button for sub-code
Aug 19, 2014 | Sharp AR-5320 Black and White Copier
My sharp ar-5320 copier is giving h and 4 alternatively
A H4 is a error code for the fuser unit is not warming up in time. Odds are the fuser heater lamp needs to be replaced > it is most likely blown or looks like a candy cane. You have to replaced the part before the code will clear. It could also be the thermal fuse or the thirmister.... I would look at the fuser heater lamp... Good Luck
Sep 29, 2011 | Sharp AR-5320 Black and White Copier
I am using Sharp Copier Model no: AR-5320 and when i replace catridge it showing F2 Please give me the solution?
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
Dec 30, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W copier giving F 5 alternatly.
thinksssssssssssssssssssssssssssssssssssssssssssss
Oct 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W Copier giving L 4 error msg alternatly
L4 is main motor drive overload. It could be a power problem going on with the copier. Are these copiers plugged into surge protectors?
If you can have a Sharp technician look at it, it would be a good idea to determine if the motor, power supply, or main board is the culprit.
Sep 21, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
Jan 22, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
189 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
