Question about HP Office Equipment & Supplies
Have HP deskjet f380 will photo copy but will not print off-screen Just get sheet of plain paper. Ink jets ok
    Guru:
  • 558 Answers
Thanks for your posting in FixYa.
Is it printing or not. Have you check in the Spooler service, is it showing connecting or sending data. Any status showing or just hanging it.
Regards
ELLIN
Posted on Sep 20, 2008
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    The ink light keeps blinking but the cartridge is full. Also what does the E above the plain/photo paper panel means.
    Hi, you can use this link to know possible codes for HP DeskJet F380 All-In-One Printer.
    printertechs.com/tech/error-codes/error-codes-A-E.php
    Nov 16, 2010 | HP DeskJet F380 All-In-One Printer
    hope it helped.
    Thanks for using fixya...
    Oct 27, 2010 | HP DeskJet F380 All-In-One Printer
    The papers come out blank on my hp deskjet f380
    check your printer ink-jet, make sure there is ink in it.
    Oct 17, 2009 | HP DeskJet F380 All-In-One Printer
    Prints documents ok but will not print photos
    Buy a photo ink catridge. Look for the number in your manual and use the correct photo paper.
    Regards
    Sep 15, 2009 | HP DeskJet F380 All-In-One Printer
    Compatibles wont work
    Try this:
    The HP all-in-one product will print black copies using both the color and black cartridges to create composite black in Normal and Best modes. This is necessary to create the correct grayscale shades.
    1. The color cartridge may be out of one color of ink. Perform the steps in the 'Colors are not correct' section above to verify that the ink cartridges are not low on ink.
    2. Verify that the correct paper type is selected in the Paper Type setting.
    3. Some photo paper has different chemical characteristics than Hewlett-Packard paper. The HP all-in-one is designed for use with HP Premium and Premium Plus Photo Paper. The photo paper, paper-type setting should be used with HP Photo Paper. For other paper brands, it may be necessary to use the plain paper or premium Inkjet paper, paper-type settings.
    OR: The ink cartage you have may be defective if is a refilled or recharged cartage.
    Jun 17, 2009 | HP DeskJet F380 All-In-One Printer
    Not a Problem but a Question
    Use a good photo-grade paper! That's it!
    I've some old vintage pictures that I have scanned and re-printed ... they turn out beautifully!
    Purchase a good quality paper for better results. I have some HP Paper as a sample, and it looks good. I had a friend who had some no-name paper and I borrowed a few sheets and they look cruddy. :)
    Jun 16, 2009 | HP DeskJet F380 All-In-One Printer
    Epson r350 printer does not print thick paper or inkjet paper
    Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
    It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
    For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
    Hope this is of help.
    Regards
    Sham
    Jun 01, 2009 | Epson STYLUS R350 Photo Printer
    Mis-alignment during printing of labels sheets
    Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
    Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
    42 people viewed this question
    Ben Johnson
