Question about Novell IntraNetWare 4.11 for PC
Print Server Configuration on Intranetware 4.11
Hello all,
i have problem with print server configured on netware server 4.11
when clients try to print ,the que goes to the server but does not get printed
on printer.i have checked with Printer cable and everything seems to be ok
the print server constantly shows a massage that printer is offline,but eventhough it is online it displays the same.I even tried unloading pserver
and again loading it back,but the problem still persist.please help me with the same.
2 Suggested Answers
mikeywaf
  • 346 Answers
SOURCE: 1. I need to connect
Greetings - Regarding Win 7 machines connecting to Netware 4.11, you need to setup TCP/IP on the server and connect Windows 7 via TCP/IP.
Regarding print servers, the tried and true HP Jetdirect Print Server series are well supported with Netware 4.11
Regards and Thanks for using Fix Ya.
Mikeywaf
Posted on Apr 12, 2011
1. I need to connect a print server that support printing with Novell Netware 4.11...any such models available in the market. 2. Since Windows 7 does not come with support of IPX/SX is there a way to...
Mikeywaf
Apr 12, 2011 | Novell IntraNetWare 4.11 for PC
Ho do I print a config page from the extend print
If I remember correctly there is a reset/print configuration button on the pocket print server. With it connected and the printer on, press it once and it should print out a configuration sheet with its settings. If that doesn't work, disconnect the power and with the button held in, reconnect the power and release the button.
Oct 09, 2009 | Extended Systems Computers & Internet
Can not install
Chapter 3 - Configuration
This section will show you how to configure your new D-Link wireless print server using the web-based configuration
utility.
Web-based Configuration Utility
The IP address of your print server will be automatically assigned by your router.
To access the print server’s web-based configuration interface:
Windows® XP users:
Double-click on the My Network Places icon on your desktop. Your print server will be displayed as “DPR-1260:
dlinkps-xxxxxx” (where xxxxxx is the last 6 characters of your print server’s MAC address). If you do not see the print
server or have UPnP enabled, please refer to page 13.
Windows® 2000 users:
You will need to write down the MAC address located on the bottom of the print server (E.G. 00-54-23-45-f5-b6). Open
a web browser and enter the following:
http://dlinkps-XXXXXX
XXXXXX = the last six characters of your MAC address.
Note: Some printer software features may not work
while connected to the print server such as ink level display.
This will prove the print server is working. If you can not access the web interface then it may not be getting an address from the router
May 22, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Zebra Z4m w/print server II has Netware enable, How do I turn it
The print server has a web access if you know the IP address. You may need to have a Username (root) and password to gain access to what you wish to change.
Apr 02, 2009 | Zebra Z4Mplus Label Printer
Installing Netware 4.11 in SATA PC
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
377
Jul 13, 2008 | Novell IntraNetWare 4.11 for PC
Novell 3.1 clint
hi
if u running on win98 then go to network neighbourhood properties install client for novell netware, install protocall named ipx/spx/netbios , and nwlink netbios then set logon method to novell netware client method restart the system and choose the prefferd server of your netwaree server run login script if u have u also have authorised account for your server.
your pro is almost solved.
bye
kishor
Feb 21, 2008 | Novell IntraNetWare 4.11 for PC
Reset edimax print server configuration
try to look for that tiny button around your print serverit is the resetter, it is the same with routers. does your print server comes with a cd installer, if yes install your print servers driver then you can assign your desired configuration for it.
Sep 09, 2007 | Edimax (PS-3205U) Print Server
Macintoshes and Print Servers, the PS110 in Particular
Topic 1. What do I need to connect a Macintosh to the PS110 Print Server? A PostScript printer with a parallel interface, a Mac running MacOS 8.6, 9.x, or 10.x. (NETGEAR products are not supported for earlier versions.), and Ethernet cables to connect the Print Server to the printer, and the Print Server to your Macs, and to a router. NETGEAR's RP614 router is known to work connecting the PS110 to the Internet with Macs. Topic 2. How do I avoid losing my network configuration when restarting my Mac? When changing theMacOS configuration it is best to use Configurations (MacOS 8.x or 9.x) or Network Location (MacOS 10.x) settings instead of changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). That way you can be sure the changes will not be lost after rebooting. To Create a Configuration in MacOS 8.x or 9.x 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. Select File > Configurations > New Configuration. 3 . Type a meaningful name for your new configuration (e.g., NETGEAR Wireless Router). 4 . Make your changes to the AppleTalk or TCP/IP settings. 5 . When closing AppleTalk or TCP/IP choose Save Changes. Whenever making Configuration changes for settings in MacOS 8.x or 9.x, open File > Configurations or press Command-K. Changes in Configurations are saved after rebooting. To Create a Network Location in MacOS 10.x 1. Open the Apple Menu by clicking the Apple icon in the upper left of the screen. 2. Select System Preferences. The System Preferences window displays. 3. Click Internet & Network > Network. The Network Settings window displays. 4. If the window is locked, click the Lock icon in the lower left to unlock the Network window. (You may be asked for a username and password.) 5. Click the pull down menu next to Location at the top of the Network window. 6. Select New Location. 7. Type a name for your new location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left to prevent further changes. The Apply configuration changes window displays. 10. Click Apply to keep the configuration changes for the newly-created location. 11. Close the Network window. Topic 3. How do I connect a Mac to the PS110 Print Server? For MacOS 8.6 and 9.x 1. Follow the instructions in the NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-PostScript printers with Macs on the PS110 Print Server.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer to be used with the PS110 Print Server on your Mac. 5. Open Chooser from Apple Menu. 6. Select LaserWriter 8. 7. Select the PostScript Printer to use. (This is probably the description for the PS110 Print Server and may have a name like ?PSD90335?. This name may be different on your computer.) 8. Click Setup. 9. Click Select PPD. 10. Select your printer from the Printer Descriptions list. 11. Close the Chooser. 12. Click OK. A message displays: ?You have changed your Desktop Printer.? You can now connect to the RP614 Router Gateway, and to the Internet. For MacOS 10.x 1. Follow the instructions in the printed NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-Post Script printers with the Mac and the PS110.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer you will be using with the PS110 Print Server on your Mac. 5. Open Utilities > Print Center in the MacOS 10.2 Applications folder. The Printer List appears. 6. Click Add. The Printer Selection window appears. 7. From the top of the Printer Selection window, select AppleTalk from the first pull down menu. 8. Select Local AppleTalk Zone from the second pull down menu below. 9. Click the Print Server from the list in the window. PSD90335 ? PostScript Printer in the case of this test. 10. Click the pull down Printer Model, and select the model of printer connected to your Print Server. A list of printers displays. 11. From the scrolling list select the Model Name of the printer connected to your Print Server. 12. Click Add. 13. Printer List displays with the list of printers and print servers connected to your Mac. Select the name of the Print Server from the Printer List. 14. Click Make Default. 15. Close the Printer List. 16. Open a file and try printing it. You can now connect to the RP614 Router Gateway, and to the Internet.
Feb 19, 2006 | NetGear RP614 Router
Novell IntraNetWare 4.11 for PC Logo
52 people viewed this question
Top Novell Computers & Internet Experts
David Payne
David Payne
Are you a Novell Computer and Internet Expert? Answer questions, earn points and help others
